Dual exhaust conversion
Old Dec 28, 2011 | 06:25 PM
silverado636's Avatar
silverado636
Default Dual exhaust conversion
Is it possible to convert a factory dual exhaust into a 2 into 1 by eliminating the left side. I like the look of single exhaust.
Will there be any adverse affects? Power increase or loss? Heat issues?
07 Electra glide 96" se255
Any thoughts?
Old Dec 28, 2011 | 06:43 PM
shore's Avatar
shore
They make plenty of 2 into 1's, haven't heard of anybody modding the stock to be a 2-1.
You'll pic up some mid range tq.
Old Dec 28, 2011 | 07:37 PM
mkguitar's Avatar
mkguitar
Yeah, the "y" pipe from the rear head, just put a freeze plug from Canadian Tire in there- be careful that you don't hammer anything too hard the Y is prone to crack if stressed and you don't want to apply any stress to the exhaust port.
If you like it after trying in out, you could remove the pipe, cut the unused left side back and weld in a permanent plug.
You will get better results with a purpose built header ( configured so as both front and rear head pipes are the same length), but your mod is cost effective fer sure.
Mike
Old Dec 28, 2011 | 07:55 PM
silverado636
I'm on the cheap as I have spent my fun money on a SE 255 cam install including buying the tools for inner bearing removal/install and buying a PV tuner. I do want a proper 2 into 1 but that will come in time as funds are available.
Old Dec 28, 2011 | 09:12 PM
coolerman69's Avatar
coolerman69
Yes you can do it. I did it a few years back and it worked great. Simply remove your left side pipe and plug the headpipe with a freeze plug. Tap it in, no need to weld it. Slide the left exhaust back on and ride.
jerryhammond1962
Nov 15, 2015 09:35 AM
racehorse
Jan 19, 2014 07:09 PM
strickrodt70
Ironhead
14
Mar 29, 2013 08:19 PM
shovelheadgreg
Shovelhead
Aug 30, 2008 03:09 PM
lvspringer
Feb 13, 2008 02:49 PM
