Equal Exhaust Pressure
Old Nov 8, 2015 | 10:45 AM
jerryhammond1962's Avatar
jerryhammond1962
Stage III
Default Equal Exhaust Pressure
I have a 2016 FLHXS with Freedom Performance True Dual Headers and 4" slipons. I had HD install a SE breather and remap the ECM. I do not have equal exhaust pressure out of the end of the pipes. This is an issue because of some special mechanisms I want to install instead of tips. Does anyone know why I would not have close to equal exhaust pressure, or at least close, on each side?
Old Nov 8, 2015 | 10:57 AM
jerryhammond1962
Stage III
Can a Moderator help me. I was trying to put this Thread in the Tech / Exhaust section. I do not know how it ended up here.
Old Nov 8, 2015 | 11:04 AM
mkguitar's Avatar
mkguitar
with a single pipe to each cylinder you will ( or should have) equal volume of exhaust gasses- the pressure may be affected by uneven header length and cooling of the gasses within the headers.
header length and cooling of the gasses will also affect the velocity within the pipe.
add cam overlap and duration and you may get differing results at idle and 3000 rpms
I can only guess that even length headers which are jet coated or wrapped ( to retain heat) would give you closer to the result you'd like.
this equal length of the rear header pipe is why bassani marketed the "power curve" which added pipe on the rt side of the bike...problem was you couldn't get to the oil or tranny fills.
to get a moderators attention, click on the yellow triangle at the top right of a post
Mike
Old Nov 8, 2015 | 11:21 AM
grbrown's Avatar
grbrown
With true-duals the only way your exhaust pressure is going to be the same out of both of them is if the pipes are the same length. What are these special tips you talk of?!
Old Nov 8, 2015 | 11:34 AM
smitty901's Avatar
smitty901
Another reason true duals are not the answer for a Harley, except in a flat out drag race . Harleys engines need the scavenging of both pipes to be their best
Old Nov 8, 2015 | 03:19 PM
SafetyMan's Avatar
SafetyMan
I beg to differ.
The difference is so minimal you can't tell the difference.
Old Nov 8, 2015 | 03:46 PM
mikelikesbikes's Avatar
mikelikesbikes
2 into 1 and forget about it.
Old Nov 8, 2015 | 03:47 PM
mkguitar's Avatar
mkguitar
Originally Posted by SafetyMan
...The difference is so minimal...
you can't, I can.
Mike
Old Nov 8, 2015 | 07:13 PM
Keithhu's Avatar
Keithhu
Originally Posted by grbrown
With true-duals the only way your exhaust pressure is going to be the same out of both of them is if the pipes are the same lengthy. What are these special tips you talk of?!
Yep, plus they take different paths. On V&H dresser duals for example, the rear cylinder exhaust has a lot more sharp turns than the front.
Old Nov 9, 2015 | 05:27 PM
jerryhammond1962
Stage III
Tailgunners
