Changing mm to delphi
Old Dec 29, 2011 | 08:31 AM
heavymetalthunder's Avatar
heavymetalthunder
Sorry double post
heavymetalthunder
sorry, triple post :
Old Dec 29, 2011 | 08:33 AM
heavymetalthunder
here's a list from the link above for the parts conversion.
A complete parts list to convert a Magneti Marelli (96-2001) to a Delphi (2002-2005) style fuel injection would look like:
delphi conversion harness
twin tec dual O2 ecu kit
delphi coil
MM conversion fuel rail
fuel lines
fuel regulator
delphi style throttle body your choice one of the following:
oem 02-05 and AC kit
S&S single bore kit
S&S dual bore kit
HP INC billet single bore
Wire Harness for Magneti Marelli conversion to Delphi
This is a very nice way to update a older bike to take advantage of Delphi type connection on the Twin Tec TCFI. The harness Plugs in to existing connections for sensors and main wire harness for a complete plug and play with no splicing, no cutting or rewiring. It is also ready for Twin Tec TCFI O-2 sensor feedback (Wego)
you have to use a throttle body that uses the Delphi IAC and accommodates the Magneti Marelli fuel system. We can recommend and supply these items
Magneti Marelli conversion to Delphi fuel rail, bolts on to a stock 02-05 type throttle body to allow the use of the Magneti Marelli fuel pump/ fuel tank. makes conversion much easier and less costly.
http://www.vtwinfuelinjection.com/
Old Dec 29, 2011 | 08:35 AM
FastHarley's Avatar
FastHarley
Former Sponsor
building a new 124 ci S&S in a 2000 frame now. I will post a how to on my site. As with all of my bikes this will be a ground up with very few HD parts. So far I found a 2004 EFI Harness and matching module. I called Zippers and HPI. Expect to spend at least $750 ~ $1K for my larger throttle body.
You need a new gas tank because the connections are different.
Old Dec 29, 2011 | 08:36 AM
Beav's Avatar
Beav
Question
Originally Posted by Badfinger
I'm pretty sure Magnetti Marelli makes the "Delphi" unit. You might contact them for info.
Why are you giving advice on something you obviously know nothing about?
Just sayin'
Old Dec 29, 2011 | 08:42 AM
reh13's Avatar
reh13
These guys have been wroking with MM injection for a while now...check em' out.
http://www.bcheads.com/index.html
96 Ultra
EVO
16
Oct 30, 2017 05:19 PM
flhchaz
EVO
11
Mar 12, 2015 03:12 PM
Andy_fxdwg
Oct 10, 2012 02:38 AM
jrike_7@msn.com
Nov 22, 2011 09:08 AM
rhinoevans
Jun 13, 2005 12:31 AM
