P1356 code on ultra
Old Dec 31, 2011 | 09:36 AM
smokindave's Avatar
smokindave
Hard to help with no info on what bike you have, everything else is just a quess.
Old Dec 31, 2011 | 12:18 PM
Lgossett's Avatar
Lgossett
6th Gear
Problem solved. Hole in the fuel line in tank. Wish I could buy you all a beer.
Tanks
Old Dec 31, 2011 | 08:02 PM
ArizonaHarleyRider's Avatar
ArizonaHarleyRider
Awesome...enjoy the ride!
Old Sep 6, 2014 | 07:24 PM
h_d_ryder's Avatar
h_d_ryder
3rd Gear
Originally Posted by ArizonaHarleyRider
Believe it or not, If you search through here you will also find its very common for the fuel line inside the tank to get a hole in it then unable to pressurize the system. Happened to my bro's bike, 07 UC. The backfire symptom as well as unable to run into higher RPS often times as it progresses it wont even idle, just backfire cough and die. Food for Thought, Good Luck...
ArizonaHarleyRider, I am have a code P1356 with my '07 Street Glide. I have no spark at the rear cylinder. I have replaced the plugs, plug wires, tested the coil, and unplugged the Power Commander, but with no luck yet.
How many miles were on your 07 UC when it got the holes in the in-tank fuel line?
Can the unpressurized fuel system issue cause the ECM Computer not to provide spark?
Thank you for the help.
Old Sep 6, 2014 | 10:55 PM
user 8373900's Avatar
user 8373900
Glad its fixed
Old Aug 22, 2018 | 12:59 PM
ValLanham's Avatar
ValLanham
Stage I
Default Code p1356
Thanks all! I just recently learned how to check codes (YouTube) & after reading your forum I checked my plug wires & found one not on. Hoping this fixed the problem!
Old May 5, 2022 | 07:33 PM
iamrclose's Avatar
iamrclose
Default Codes on 2014 UL
I have a 14 UC and the ECM threw a code P1356? so has anyone came up to what causes this and a fix for it as well? Bike was purchased used with 35,000 miles on it and I have only put 2,073 miles on it self
Old May 6, 2022 | 06:37 PM
woodthumb2's Avatar
woodthumb2
codes are the same on all i think
sincityharley
Electrical/Lighting/Alarm
Jun 25, 2017 01:55 PM
emnnitetrain
Oct 2, 2013 10:04 PM
emnnitetrain
14
Oct 1, 2013 11:49 PM
TexFF
Jun 5, 2013 09:42 AM
errasa
May 3, 2008 07:10 AM
