Chirping noise
Old Jan 2, 2012 | 11:32 PM
davessworks's Avatar
davessworks
Originally Posted by 2black1s
Where is the dent exactly? Is it possibly from the rear axle hitting the muffler on suspension rebound? The stock mufflers have a huge depression in them just for that reason but most aftermarket mufflers do not. Although the right side is the one to usually hit first because the nut on the axle sticks out a little farther than the welded end.
Try to imagine somethingg falling on the outer edge of the muffler. These mufflers do not have rounded ends - it's a cut end. (see part 80847-10)
Imagine the back outer surface facing you in the picture above had been pushed in a little. Now instead of it being the right side - imagine the left. This isn't a clearance issue. Something wacked the end of the muffler from the side.
Old Jan 2, 2012 | 11:44 PM
2black1s's Avatar
2black1s
I'm familiar with the mufflers, I just put the same ones on my bike a week or two ago.
I'm still trying to picture the location of the dent. But it's not the clearance issue - different location. I have no clue as to the cause.
Old Jan 2, 2012 | 11:52 PM
davessworks
There are no clues - wish there were. Dent is just above the letters "l" and "t" in the posted picture.
It's as though something fell against the bike but only hit the muffler. How are you liking them? I switched from a more open design (but too loud) and probably lost ~4 hp.
Old Jan 3, 2012 | 10:50 AM
2black1s's Avatar
2black1s
I'm pretty happy with mine. I put 5 extra discs in them for a total of 15. I was going back-n-forth between stock mufflers and Jackpot DynoTuned mufflers. The Jackpots sounded great at idle and easy cruising, but were too loud (for me) under hard accel/decel. The stock mufflers were ok but just didn't have the right tonal quality. The Fatshotz are just a little louder than stock, with a nicer tone, and they don't get too loud when standing on it. That's what I was looking for. As far as HP change goes, I don't know, and I don't care - I'm happy with the way it runs.
Old Jan 3, 2012 | 11:28 AM
Denver Dave's Avatar
Denver Dave
My chirps were coming from the rubber hanger mounts also. My fix - I cut a small piece of rubber off of a bicycle tire tube and stuffed it with a screwdriver between the rubber and metal. Takes 3 minutes, cost is zero, and problem solved.
Old Jan 3, 2012 | 11:52 AM
MNAY0227's Avatar
MNAY0227
I had a chirp didn't start until it got hot.After it got hot the chirp would start every time i stopped.If i stood up the chirp would go away tried the muffler bracket isolators still didn't fix it tighten the exhaust still nothing.Finally found out that my swing arm was loose, so loose that when we were tightening it up thought it was stripped.
Old Jan 3, 2012 | 12:09 PM
Uncle Larry's Avatar
Uncle Larry
That's scary !
Old Jan 3, 2012 | 12:15 PM
Denver Dave
Also.... I will be checking my swingarm today. Just in case.
Old Jan 3, 2012 | 12:21 PM
jjnoble's Avatar
jjnoble
The belt can make that noise. You might need to put some poly lube on it.
Old Jan 3, 2012 | 12:52 PM
DHubbs's Avatar
DHubbs
I dont mean to hijack the OP thread, but am wondering if the OP's chirping noise is like mine.
My bike makes a chirping noise comming out of the exhaust,,,(1) only when accelerating (2) only when on a concrete surface & when riding beside a concrete barrier, such as a interstate hwy.
I have heard others with Rinehart slip ons complain about this, have yet to read about a fix for it. It sounds like a VW beetle when ridding with those conditions. Others riding beside me or behind me say they cant hear it, I know I do!! Anybody else hear this with there ride? Anybody know of a fix?
draggingframe13
Aug 13, 2013 11:42 PM
dougbk
Sep 6, 2011 07:09 PM
Weed's Ironscoot
Oct 22, 2010 10:02 PM
UCRED
Apr 2, 2008 08:50 PM
veniculum
Aug 21, 2006 06:19 PM
