Transmission End Cover Gasket.
Old Jan 3, 2012 | 11:13 PM
Wally's Avatar
Wally
Default Transmission End Cover Gasket.
Is is absoluely manditory that we chage the transmission end gasket? We're putting a D&D Fatcat on buddies bike, and we don't have the gasket. It'll hold us up a couple of days if we have to order one.......
Old Jan 3, 2012 | 11:17 PM
Toypuller's Avatar
Toypuller
Biggest issue you will have is a seepage leak.
It will hold until you can order one. Or it may not leak at all and you are done.
I'm in the school of change gaskets every time, but even I reuse some.
Old Jan 4, 2012 | 12:01 AM
mkguitar's Avatar
mkguitar
never had to replace one...maybe I'm lucky.
before you start, roll the bikes tires up on a 2x4, so that when on the side stand, the angle is much increased- that'll keep all the lube in the tranny
make sure the bike is stable on the stand!
if you are unsure about the seal, lightly coat it with silicone, let dry then re-use.
note that the torque spec for those bolts has been increased to ( I think) 23 ft lbs - too lazy to go the the garage and check)
mike
bellmnbell
Dec 8, 2016 04:07 PM
theterribleone_vdc
Aug 24, 2016 08:26 AM
Bulldog21
Aug 21, 2008 10:15 PM
monsterdeluxe
Nov 15, 2007 12:59 PM
opiate9680
Nov 3, 2005 07:38 PM
