Gear drive?
Old Dec 10, 2006 | 12:33 AM
Maddogs700srx's Avatar
Maddogs700srx
Default Gear drive?
I am considering the switch to gear drive cams along with a 95" kit. Looking for cost and difficulty of installation. Thanks
Old Dec 10, 2006 | 12:47 AM
Bryan TTM's Avatar
Bryan TTM
Default RE: Gear drive?
in the 700 range...and not that hard....use a buddy with a screwdriver to hold the cam tensioner out of the way and then wiggle the plate off..take it to an indy and have him press em out and the new ones in...you'll need a bearing puller/installer to change bearings...the rest is easy....i cut my pushrods with boltcutters and replaced em with Jims ProLites...you'll have to take the pipe & board off tho
Old Dec 10, 2006 | 12:57 AM
xxxflhrci's Avatar
xxxflhrci
Easy job. I did it without a press for installing the cams. I used the oven/freezer method. Worked like a charm.
Here's a good guide:
http://www.harleyhog.co.uk/1550/bbonline.htm
pounder35
Apr 3, 2014 01:18 PM
slammed05fatty
Apr 1, 2014 02:06 PM
jslum
Jun 16, 2012 06:27 PM
electra glide
Nov 23, 2009 07:34 PM
Naz_Man
Jul 10, 2009 06:33 PM
