clutch change question
Old Jan 8, 2012 | 05:46 PM
Hoblick's Avatar
Hoblick
Default clutch change question
i have the manual, but some of the wording, and how they break down the procedure is odd.
to just check or change out clutch plates
do i need to do anything aside from..
loosen clutch cable at the adjuster on the cable
pull outer primary cover off
remove clutch nut and adjustment rod
take the 5 bolts that hold the clutch spring
and start pulling apart
or do i need to do anything else.
in the manual it only shows the procedure to pull the entire basket out, which entails locking the compensator and clutch baskets, then taking the primary chain off and so forth.
shouldnt have to do that to just pull the clutch spring and plates correct?
Old Jan 8, 2012 | 05:49 PM
mkguitar's Avatar
mkguitar
correct.
mike
Old Jan 8, 2012 | 06:00 PM
aviscomi's Avatar
aviscomi
Just out of curiosity...why are you changing it?
Old Jan 8, 2012 | 06:01 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
I agree that will do it. Give the 5 bolt a couple turns in a cross pattern out and in to keep pressure equal. Note carefully how it comes apart. There is a reverse damper cup spring and seat in the very back of the stack. Be sure it points correct direction Think they are to help break the stack when you clutch to ease the bang. 'note I said ease, not cure...HA' I was in mine at 30K and the clutch looked measured like brand new.
Old Jan 8, 2012 | 06:05 PM
Stiggy's Avatar
Stiggy
And DO NOT TOUCH the clutch lever, ( as in pull it in,) during this process unless you want to see what's under the clutch actuation cover on the right hand side.
You will "flip" a 3 ball ramp that must be reset, so leave it alone until you are done with the clutch.
Old Jan 8, 2012 | 09:05 PM
Hoblick's Avatar
Hoblick
Thanks guys! Been inside the right side cover when i changed the clutch cable, so i know all about the ball and ramp setup in there
Old Jan 8, 2012 | 09:06 PM
Hoblick's Avatar
Hoblick
Oh and is the special tool "required". To reinstall the spring?
Old Jan 8, 2012 | 09:14 PM
dawg's Avatar
dawg
Nope, older bikes with actual "springs" did.
Old Jan 8, 2012 | 09:17 PM
SICKBAGGER's Avatar
SICKBAGGER
No it just stacks on like another plate.
Old Jan 9, 2012 | 01:04 AM
Hoblick's Avatar
Hoblick
thanks guys..
this will be the first time doing any work on the inside of the primary, so its nice to get some insight from people who have done it vs. just reading the manual.
although all the working components on this bike are very simple designs, its more complicated to me since i have never worked on one before this bike. always had jap bikes before which have become second nature for me to work on.
WEATHERED59
May 13, 2017 02:51 PM
Bookie
Oct 12, 2016 10:06 AM
tonycap
EVO
14
May 24, 2013 11:44 AM
kmealp
Apr 5, 2010 06:02 PM
pete.uk
Apr 20, 2006 06:11 PM
