Tour Pac hinge replacement gone wrong
Old Jan 10, 2012 | 07:33 PM
dynawideglider's Avatar
dynawideglider
Originally Posted by 1flhtk4me
Add this to the dumbshit list!
There you have it, the entire point of this post.
Old Jan 10, 2012 | 08:01 PM
Uncle Larry's Avatar
Uncle Larry
Well thanks for your support!
Would have been ok if I just held the lid,I know 20/20.
20/20 Hind Sight .... or ... Optical Rectumitis !!!
Old Jan 10, 2012 | 11:33 PM
Bill03E's Avatar
Bill03E
A trick to removing the old rivets is to use a dremel tool to grind off the heads, on the inside, you get grind marks on the washers, but you replace them anyway.Then you can drill the holes out without spinning the rivets.
Old Jan 11, 2012 | 02:25 PM
Nute's Avatar
Nute
Well I was replacing the hinges on my tour pac with the deluxe ones.I had the hinges mounted and was connecting the lid cable at the lid.Without supporting(cable on post) the lid I reached down into the pac to grab the screw and next thing I know,the phucking cable slips off and the lid flips over and CRACK!
Now there is a 2 1/2" long crack from the front hinge mount.
I bought some black ABS cement and placed some in the crack.I let that dry overnight.The next day I used two pieces of fiberglass mesh tape used for drywall.I placed the tape on the inside covering the crack and applied 2 layers of cement.Also made an aluminum support to replace the two metel washers.Seems to be sturdy.From the outside it looks like a scratch.
Got a qoute from Lake Shore......$517 for a color matched bottom with free shipping.Not sure what I'm going to do.
Save your money. Check out this site and learn how easy it is to fix it yourself or have a professional do it for a lot less than a new one.
http://www.sportrider.com/hands_on/1...ody/index.html
Old Jan 11, 2012 | 02:38 PM
HarleyRanger's Avatar
HarleyRanger
My dealership installs these hinges for a cuppla hundred bucks. At first I thought it was too much $$ and I would just do it myself. But after reading several threads about what can go wrong I am more inclined to let my dealer do the install.
Old Jan 11, 2012 | 02:43 PM
trackadaptor's Avatar
trackadaptor
Originally Posted by HarleyRanger
My dealership installs these hinges for a cuppla hundred bucks.......
Holy I'll do these all day long for $ 50.00 , it's not that hard with 2 people... as I posted:
Great Pictures and write up:
http://www.hdtalking.com/harley_davi...hinge_kit.html
It was pretty much a caveman level project. Like I said, instructions were very good for a change. A helper to hold things steady while you tighten the screws would speed things up but is not absolutely necessary.
Two tips I can think of:
1. Instructions say to drill out the old hinge rivets with a 3/16 inch drill bit. I decided to start smaller and work up to that size bit if needed. Got the rivets out with a 1/8 inch bit just fine. Only later did I discover that the new screws (16 of them total) wouldn't fit through the 1/8 inch hole that remained behind so I had to go back and redrill the holes with the 3/16 inch bit anyway. Save yourself some time and use the 3/16 inch bit right from the start.
2. I used one of the old hinges to compress the tour pak lid gasket while drilling out the rivets hiding behind this gasket. Still managed to slightly crease the gasket with the drill but nothing major. This is where an extra set of hands would also have been really nice.
Oh, and be careful after the rivets and backing plates pop off - those dudes are HOT from the drilling!
Old Jan 11, 2012 | 07:39 PM
KW-HD Rider's Avatar
KW-HD Rider
I also thought it was fairly easy but of course nerve racking drilling the tour pack. I did have help holding the tour pack while securing the new hinges. Can't imagine how hard it would be to do it by your self. And yes we have all done dumbs**t just most won't admit it....
Old Jan 11, 2012 | 08:33 PM
bald1der's Avatar
bald1der
Originally Posted by IAMSWUTIAMS
Can the install be done solo, or is a second pair of hands really "needed"? I hate to ask the Wife for help.
Can be done solo. My wife just sat in her chase chair and watched me do mine. For me it helped that my T/P is detachable. I did it while watching a football game.
Old Jan 11, 2012 | 08:49 PM
1flhtk4me's Avatar
1flhtk4me
It can be done solo,just dont do what I did!
Old Jan 13, 2012 | 11:18 PM
kdodd's Avatar
kdodd
Ebay is a great place to find stuff like that, good prices. I have gotten a lot of upgrades for my bike there.
