Led and security??
Old Jan 10, 2012 | 11:33 AM
Tee Bagger's Avatar
Tee Bagger
Default Led and security??
I put led bulbs in the the turn signals. When I turn the signal on it flashes 4 times at the normal rate, then increases to twice as fast as normal. Also, the security light on the dash comes on...I do not have the security option. Coincidence?? I did not use load equalizers...is that why??
Old Jan 10, 2012 | 11:36 AM
mkguitar's Avatar
mkguitar
Ever wondered why they make load equalizers?
Mike
Old Jan 10, 2012 | 11:42 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Mike
+1
Old Jan 10, 2012 | 11:43 AM
Tee Bagger's Avatar
Tee Bagger
Hey thanks for the help?? Is this why the security light is comming on?? Thats what I want to know.
Old Jan 10, 2012 | 12:08 PM
Aborigen2's Avatar
Aborigen2
Yep, the light is comming ON because the system detects your LED lights as "open" (too little current). If you check the codes you'll find "open" codes for your turn signals. Same way the lights flash at double rate to allert you that there is something wrong with the turn signals (it works the same way on cars, too).
The light is actually not just a Security Light but a MIL- Light (Malfunction Indication Light). It is used by the non-security and security modules. The difference is that on Secuirty Module it is used when Ignition is OFF as well to indicate "Armed" state.
You may option not to install any load equilizers if everything is working OK. The consequences are that when you have a real trouble code set for some other reason you'll no notice it since your MIL light will be always ON.
Old Jan 10, 2012 | 12:10 PM
Tee Bagger's Avatar
Tee Bagger
ahhh. Thankyou. I have no problem with the way they flash. Going to leave them as is for now. Was just concerned about the security light.
Old Jan 10, 2012 | 05:58 PM
1sweetglide08's Avatar
1sweetglide08
Kuryakyn makes a load equalizer and a alarm compatible load equalizer part # 21-1153 that will prevent your alarm light from staying on. I brought both when I installed my LED's but ended up not needing the alarm equalizer. I can sell u the alarm equalizer for $20.00. Never opened new $28.99.
rangerider547
Electrical/Lighting/Alarm
May 17, 2016 03:41 PM
jagonza1
Jun 14, 2010 11:09 PM
maineultraclassic
Aug 3, 2009 03:17 PM
glide05
Mar 2, 2009 04:13 PM
mrbuck
Jan 19, 2009 09:44 PM
