Auxillary Switch
Old Jan 12, 2012 | 06:13 PM
EricD10563's Avatar
EricD10563
Originally Posted by jimglassford
Exactly what did Harley intend for this switch? The owners manual states it is for dealer added accessories under the seat. I have ABS so there is no room under the right side cover. It does not look like anything will fit under the seat. So what did the factory have in mind?
I have my Fog Lights wired to the switched wires and the other that are igintion on I have my Tour-Pac side lights wired to that.
Old Jan 12, 2012 | 07:16 PM
mike79's Avatar
mike79
Thanks every one. I appreciate all the info.
Old Jan 21, 2012 | 08:37 AM
engr146's Avatar
engr146
Default 95 RK aux switch relacement ?
I broke the aux switch inside when trailering ,when I bought bike,It must controll the power to engine LED's and cig lighter .
I don't see in the HD Factory manual any info on the removal of RK toggle switches ,just the EG with nacelle
How do I get at it to remove and replace,and is it just a 2-prong standard waterproof switch.THX
Old Mar 12, 2012 | 08:39 PM
2010 Raffel Road King's Avatar
I have a 2010 Road King and I must be missing something because I see no plug under the seat? I got a 12 volt plug as described earlier and don't see where in the world to plug it in? Any help on this would be greatly appreciated.
The only plugs that I see are under the side cover. One is for diagnostics I believe and it has 3 male prongs in it. The other plug is female and it as 4 wires in it. I don't know why Harley has to make things so difficult.
I did get an auxiliary harness to hook up the led lights on my luggage rack and tour pack. Even with that harness extension, I had to older in a ground wire to get it to work.
Old Mar 13, 2012 | 10:28 AM
Nute's Avatar
Nute
My Road Zepplin seat plugs right into the aux. plug under the seat. Just another Harley Accessory to mention. I also have the "Y" adaptor which I plug my HD Cig. socket into.
Old Mar 13, 2012 | 11:31 AM
Can someone who owns a 2010 or newer Road King tell me where the Deutch accessory plug under the seat with 4 leads is located? Is it tucked under the battery lid?
Old Mar 13, 2012 | 11:43 AM
mrfikser's Avatar
mrfikser
its tucked in between the front of the battery and the metal frame piece, by the coil ...towards the front of the bike..it may have a wire cable thingy on top of it
SuperGlide206
Apr 5, 2018 08:21 AM
realjewel69@gmail.com
General Topics/Tech Tips
17
Dec 18, 2016 10:58 AM
drew1879@gmail.com
Aug 15, 2014 05:29 AM
capt_caveman
Mar 27, 2011 09:56 PM
Potato_Potato
Oct 20, 2008 04:04 PM
