LOW SPEED tank slapper??!!??
Old Jan 24, 2012 | 07:39 AM
Hog Yild's Avatar
Hog Yild
I'm thinking the neck bearings need tightening. My Ultra would ride straight and true hands off the bars as long as you had throttle or constant speed on it. Slowing down to a stop, about 2200 rpm the bars would start to tank slap without hands on the bars. Had the neck bearings tightened and the problem went away regardless of what load I was carrying. You may be just getting to the point they should be adjusted.
Old Jul 22, 2013 | 12:16 AM
kornflake's Avatar
kornflake
6th Gear
I just did a test ride on a new Harley Road Glide Ultra
and wen slowing down I got a full on tank slapper when I let go go the Handel bars
This is normal according to Harley
Is this bill s@&$t ?
Is the a good fix for this like a Stering stabilizer
Other than the low speedtank slapper Stering problem
The bike rode just fine.
Honestly unless I can find a perminute fix for this
It ts a definite deal breaker.
Old Jul 22, 2013 | 12:51 AM
user_1534GD's Avatar
user_1534GD
All good info thus far...
VERY curious problem... The RPM-link is significant/intriguing and that you can feel a suspicious vibration through the rear brake... The tour-pak connection is odd but not out of the realm... I assume that you have checked all engine mounts, stabilizers and wheel bearings... Perhaps the RPM 'connection' is that it creates a peculiar 'harmonic' that triggers/enables this tank-slap pheno... There is a fair amount of lateral flex in that frame and with an additional 'issue' such as neck-bearing, wheel bearing, engine mount, stabilizer problem and added tour-pak/weight... Who did the work for the tour-pak docking/mounts... Check that mount and the rear shocks symmetry... I am just thinking out loud here guys...
thoner7
Jun 28, 2019 12:24 PM
JohnnyRebKY
Jun 7, 2014 09:02 AM
pointblank
May 24, 2011 10:33 AM
roadrunner68
May 10, 2007 01:28 PM
KenM
Nov 18, 2005 01:42 PM
