Fuel Management for Idiots
Old Jan 17, 2012 | 11:55 AM
Harleybar7's Avatar
Harleybar7
Default Fuel Management for Idiots
Got some good tips thanks
Old Jan 17, 2012 | 12:12 PM
ngoti8tor's Avatar
ngoti8tor
You can get away without fuel management if you only do the air filter or the pipes, but not both.
The Power Commander V would be a good one to get in case you do any other engine mods.
If you wanna go cheaper yet and don't intend on doing any other engine mods, you could get the V&H Fuelpak like me.
Old Jan 17, 2012 | 12:13 PM
Keithhu's Avatar
Keithhu
The truth is you can do pipes and AC and the ECM and sensors will adjust, anyone who says it will run too lean and blow up is just wrong. Now, that said, what the ECM adjusts it back to is the same lean-ness of the EPA spec.
So if you want a fuel management system, there are a lot of choices. They do 2 basic things (there's a lot more complexity under each, but really its 2 major things) 1) adjust/modify Air Fuel Ratio (AFR - how rich/lean), and optimize performance (timing, VE tables, advance, etc)
For a basic overview of the *kinds* of options there are, you can start here: http://www.nightrider.com/biketech/m...i_upgrades.htm
Old Jan 17, 2012 | 12:21 PM
mkguitar's Avatar
mkguitar
welcome to the maze...
I stumbled into a while ago, after about mastering carb tuning- i have some automotive training.
on my bike ( 09 FLHTC) which i bought with 5000 miles, the motor would ping under certain repeatable conditions ; 6% grades between 2800~3200 rpms.
I used nightrider.com XIEDS to solve that ( $125 and done).
From there I changed to hi flow mufflers for a 1000 miles, with good result, then put on my ness big sucker and have been fine for many thousands of mile under varying conditions.
many riders have good results with out xieds, reflash, tuner etc.
In my case the ping problem needed to be addressed first to prolong the service life and reliability of my motor.
Pinging sounds like peebles rattling in a coffee can, and is most likely to occur under high heat/ high load ( pulling up a hill, sudden acceleration) conditions.
Good Luck, Mike
Old Jan 17, 2012 | 12:26 PM
XARAN's Avatar
XARAN
+1, also go to the ECM Section here and start reading. Also call Jamie at Fuel Moto he can help steer you in the right direction.
In short if you want the bike to run cooler and better by getting it out of the EPA lean zone you have a couple basic categories of tuners
1. piggyback tuners, PC, Fuel Pak, DFO , Cobra etc. They are less $ but stay on the bike in in some cases have limitations in that they may only be fuelers and not be able to adjust the timing etc
2. Flash Tuners , SERT, SESPT, TTS, Power Vision. These tuners all have the ability to flash a different MAP to the ECM . This allows full ability to tune the bike , fuel and timing and set many other parameters. They don't stay on the bike.
Ive used both and Im currently using the Power Vision from Fuel Moto and find it the easiest tuner yet with a great deal of flexibility.
Your riding the top of the line bike don't skimp out at the last piece of the puzzle IMO
Old Jan 17, 2012 | 12:43 PM
Harleybar7's Avatar
Harleybar7
So I am thinking mabe I should pony up for something like the Power Commander to cover my *** and be able to do things later if I so desire. Can I just do A generic map or do I really need the Dyno. Seems like the dealers figure everybody has unlimited cash and will gladly take it from you. Not that I don't trust them but it's easy to spend someone else's $. Also, any issues with the HD warranty? What about HD's tuner.
Old Jan 17, 2012 | 12:48 PM
Keithhu's Avatar
Keithhu
Go with a Power Vision and a map from Fuel Moto for your combo. The Power Vision is not a piggy back system like the Power Commander, its a flash tuner. Free maps for life from Fuel Moto, so if you make a fairly common change (cams, for example), he'll have a map for you. Plus you can log the data and have the device suggest changes for you.
Old Jan 17, 2012 | 01:31 PM
Harleybar7's Avatar
Harleybar7
I will call Fuel Moto and talk to them. I guess I am just not familiar with their product. I just want to make sure that when I take my bike into my local dealer they know what to do with it. I know they deal with HD's and Power Commander. But I really like the idea of getting the info. from the source. Plus supporting an independent business. And thanks everyone, I appreciate the input.
Old Jan 17, 2012 | 01:47 PM
$tonecold's Avatar
$tonecold
Put the ac on and if it runs ok drive it. I posted some dyno sheet yesterday of an 08 RG I had that actually richened up (under full throttle) when I put D&D 2:1 and ac on it. I will probably run somewhat better with a tuner, but not much.
Old Jan 17, 2012 | 01:50 PM
XARAN's Avatar
XARAN
Fuel Moto is the dealer for products by DynoJet like Power Commander, Power Vision, they also sell other brands of tuners and offer lifetime customer support. Your dealer know the products even if they dont want to work on them.
But with Jamies help you can easily in 10 minutes or less load a custom MAP that will improve your performance. Then if you use a device like the Power Vison you can data log and self tune with the use of your PC to get virtually the same outcome as a dyno tune.
Call them and ask some questions.
