Project "Cheapskate"
Old Apr 9, 2012 | 08:07 PM
  #491
Batman7349's Avatar
Batman7349
Originally Posted by Bill03E
Do you buy your materials locally or online? I have been looking at painting a motor home, and materials are going to be in the order of $800 and that doesn't include paint.
I buy locally from a mom and pop parts store that has an excellent paint department. I use PPG Deltron basecoat, PPG Concept clear, PPG DT reducer, PPG DP epoxy primer. Then I use Transtar primers, sealers.
Old Apr 9, 2012 | 08:10 PM
  #492
Concrete Man's Avatar
Concrete Man
Originally Posted by fatmatt1962
You know I am going to chime in here. Plan on the Fayetteville trip. It is one of the best rides you will ever go on. I have been riding Arkansas for 5 years now. I have rode to Yellowstone but none can be as much fun as riding the hills in Arkansas. People are great, food is good and the view is never the same.
Trying not to hijack this awesome thread, but... Last year during Bikers Blues... Some buddies and I rode down to Eureka instead.
About 20,000 bikes vs 100,000 or so...a little more my speed, but still a great time!
Probably do the same this year.
(please excuse the interruption. Now back to work everyone.)
Old Apr 9, 2012 | 08:23 PM
  #493
Concrete Man
Originally Posted by Batman7349
Thanks for the Invite, just checked calendar and I'm in Ft. Worth, Tx that week, but next time I'm in Springfield I'll give you a PM. I'm thinking about the Bikes and Blues BBQ over in Arkansas Sept 28th & 29th. Stay and Mammoth Spring and ride over to Fayetteville.
10-4 on the pm next time you're in Springfield.
I'd try to sneak out from the wife and kids, and buy you a burger and a beer.
Old Apr 14, 2012 | 03:56 PM
  #494
Batman7349's Avatar
Batman7349
Finally got time to work on the rear fender. It's been a while but I decided to smooth it and use a S/G tail light and turn signals, which means the holes on the bottom of the fender gotta go. Being the cheapskate that I am means instead of purchasing a smooth fender I'll fill the holes. Here we go.
First take some scrap paint prep 16 Ga metal, put behind the holes to fill, and draw an outline with a felt pen. Then cut out your plugs file or grind to fit the holes.
Then I use masking tape to hold them from the back while I carefully spot weld them in place using a mig welder on low heat.
Forgot to take pictures of the spot welded plugs, sorry. Basically I just hop from plug to plug and make a little weld, moving around keeps them from getting to hot and warping the metal. I also filled the two little hole by just welding them shut, no plug.
Now grind the plugs smooth and put a skim coat of filler on. Then to the booth for primer.
And yes I filled over the stud instead of cutting it out and welding in another plug.
The primer is drying while I wait for the tornado warning to expire, then hopefully back to the shop, sand the primer, spray sealer, and paint.
Old Apr 14, 2012 | 06:25 PM
  #495
Thedink's Avatar
Thedink
Can you snap a pic or 2 of what you uses as a paint booth? Any tips on at home bike painting?
Old Apr 14, 2012 | 08:23 PM
  #496
IamKnuckles's Avatar
IamKnuckles
I love this thread. Great job! I can't wait to see it finished.
Old Apr 14, 2012 | 08:57 PM
  #497
traveler's Avatar
traveler
looks great!
Old Apr 15, 2012 | 07:10 AM
  #498
Batman7349's Avatar
Batman7349
Years ago I used to paint out of my single stall garage. I had a furnace blower mounted in the back wall, and I would remove a couple pieces of glass from the overhead door and replace them with furnace filters. It worked pretty well. I had about eight 4' florescent lights mounted on the ceiling.
30 years later I have a 30 X 50 detached pole barn that I built a paint booth inside. It is 15 foot wide and 24 feet long. I found an DeVilibis exhaust fan on craigslist for $200. There are six eight foot florescent fixtures on the ceiling from an old warehouse. Then there are six 4' four light fixtures in the side walls.
Most of the time I have a 73' Dodge Challenger project parked in it. I needed a change of pace and decided to do a bagger over the winter (now spring).....
I don't do this for a living, Just a hobby, and a place to escape to. Turn on the stereo, light up a stogie and play.
Old Apr 15, 2012 | 08:20 AM
  #499
tidbit1's Avatar
tidbit1
Not anything new can be added as far as compliments, so I will just use that now days over used word "awesome". Your talents are amazing and envied by many of us. It will be a project to be proud of when you lower from the lift, then fire that bad boy up and roll out the door.
Ride with pride and safety in mind on that beauty.
Old Apr 15, 2012 | 11:01 AM
  #500
Batman7349's Avatar
Batman7349
Thanks tidbit, I appreciate all the followers that keep checking in.
In the booth now, sealer is on the rear fender and the bag lids. The final items to paint. Then on with the assembly. Pictures later after the clear is on.
