bars
Old Jan 26, 2012 | 05:29 PM
jsklari's Avatar
jsklari
2nd Gear
Default bars
Hi,
I have a 05 ultra classic and want to switch out the stock handle bars for a set of 12 inch, How big of job is it to do the switch?
Thanks,
Lawman
Old Jan 26, 2012 | 05:34 PM
dawg's Avatar
dawg
Get the HD manual first. I'd also suggest the -08 and later one piece top clamp as well as polyurethane bushings upon reinstall. You have to remove the outer fairing, inner fairing switch cap and ignition, pull the radio, drop the exhaust if stock crossover to gain access to tranny side cover for clutch cable change, have to change out the other cables and extend the wiring. Tedious, but not hard if you follow the manual and take your time.
Old Jan 26, 2012 | 05:46 PM
Mr HOG's Avatar
Mr HOG
It's not an easy job...i've done a few bar swaps. Internal wiring also complicates things. I guess it just depends on how confident you are with your wrench abilities. On a scale of 1-5, with 5 being most complicated, i'd give it a 3.5. The good thing is there is always help here on the forum if you get stuck.
Old Jan 26, 2012 | 05:49 PM
buggy's Avatar
buggy
Not hard ,but time consuming.
Old Jan 26, 2012 | 06:01 PM
TUCCI's Avatar
TUCCI
I found the manual to generate more questions than answer....the pictorial DYI threads I've read here have been worth their weight in gold.
Old Jan 28, 2012 | 10:04 AM
jsklari's Avatar
jsklari
2nd Gear
Thanks guy's i'll take my time as it's winter and I won't be riding for a while.
robw
Aug 28, 2013 09:02 AM
Rickm
30
Dec 18, 2012 11:06 AM
chidiver
Aug 2, 2011 11:16 AM
mikes4692003
Apr 7, 2010 06:15 PM
JWhip
Apr 2, 2010 09:26 PM
