Lifters fell out
Old Jan 26, 2012 | 06:27 PM
Spur56's Avatar
Spur56
Default Lifters fell out
Doing cam replacement and rear cylinder lifters fell out. Guess the clip let lose. I put them back in and reclipped. Anything I should be concerned about?
Thanks
Old Jan 26, 2012 | 06:31 PM
RHillbilly's Avatar
RHillbilly
If they are stock make sure they are in the right way
Old Jan 26, 2012 | 06:58 PM
Spur56's Avatar
Spur56
What do you mean by right way? Thanks
Old Jan 26, 2012 | 07:01 PM
dawg's Avatar
dawg
He meant oil feed holes to the front or rear. It really doesn't matter, however you can pull one of the ones that didn't fall out and see if the hole is toward the front or rear and put the ones that did fall out in the same manner.
Old Jan 26, 2012 | 07:28 PM
Spur56's Avatar
Spur56
Thanks guys
Old Jan 26, 2012 | 07:48 PM
Spur56's Avatar
Spur56
Dawg
You said the oil feed hole really does not matter. Is it worth going back in to verify?
Old Jan 26, 2012 | 07:51 PM
dawg's Avatar
dawg
If it's already closed up, then no. You'll be fine.
Old Jan 26, 2012 | 07:56 PM
Spur56's Avatar
Spur56
Thanks Dawg
It is hell being impatient and ADD! Even have the manual just went brain dead. Happens to me often.
Old Jan 28, 2012 | 09:58 PM
bad news's Avatar
bad news
3rd Gear
The same thing happend to me today. I still have the bike apart. I used the jumbo sized paper clamps and made a tool to hold the lifters in the bores while I removed the cams. The rear lifters fell down into the cam chest. I know the manual talks about a antirotation pin that keep the lifters in place. My thinking is to remove the lifters and make sure the oil hole in the lifter is toward the inside. But do you think I should remove the lifter covers and make sure the anti rotation pin is in place. Any help would be apprecieated
mbierbac
Exhaust System Topics
Feb 2, 2012 03:49 PM
jackinthebox
13
Nov 15, 2010 10:08 PM
Rock1
EVO
Jun 26, 2010 08:11 PM
geronimo73
EVO
Aug 17, 2009 11:37 PM
mafosa
Sep 7, 2008 11:20 PM
