belts for a 1990 flht
Old Jan 27, 2012 | 01:02 AM
machinehed's Avatar
machinehed
Default belts for a 1990 flht
Anyone know the correct belts for primary and drive belt for a 1990 flht police ?
Old Jan 27, 2012 | 02:20 AM
mkguitar's Avatar
mkguitar
rear belt 136 tooth- 40001-85
primary chain- 40037-79 ( yes, chain in the primary)
check the pulleys dont have gouges in them.
if you want a 15% overdrive you can use the 61T pulley and the 132T belt- your bike would need some grunt to take advantage of this...I did this on my FXR.
here's an online parts finder, select year
model
assembly
the part numbers are shown in the cart, and you can jot them down.
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
mike
Old Jan 27, 2012 | 04:19 AM
grbrown's Avatar
grbrown
61T is International spec, I had one on my 1990 FLHS when it was new. I now have a US spec 70T, which is much better, even with my 107" motor! I don't recommend you fit one, it will raise your gearing by 15% which is frankly too much. The only reason they were used is that in some foreign markets the noise regulations were more strict than US market.
Redrodyankneck
Shovelhead
Aug 13, 2021 02:48 PM
jhonn
Shovelhead
Apr 30, 2014 01:46 AM
ctluba
Wheels/Tires
Sep 20, 2012 07:18 AM
jwcholland
Shovelhead
Aug 14, 2008 12:33 PM
richk357
May 28, 2008 05:41 PM
