Just added floor board extensions
20-25 mins per bike, oh and a trip to home depot for a 3/8 socket driver in 3/8 in hex key to get my bolts out of the SG, and we were done
Haven't driven anywhere yet but have a rally we are doin tomorrow so I will feel the difference then
Thanks for the great service harleygoodies!
alrighty Chills these are for you, and only you buddy, no one else look at them
Here's the Streety
for those that do not know, the extensions on the FL's are down where the factory floor board mounts come off the frame. You unscrew the factory bolts that hold the floor board mounting arms, use the new longer bolts from the kit along with the new spacers that push the floor board mounting arms out further almost 1 inch, and as you can see away from your exhaust!
Here's the FB
These actually instal diferently, for these you remove the floor board from the floor board mounting arms, install those trick little stainless brackets onto the floorboards, then re-install the newly extended floor boards back onto the floor board mounting arms, but they are pushed out by almost 1 inch. Again away from the exhaust and in what seems to be a much more natural riding position for your legs, as you no longer have to HUG the tank with your thighs or knees to keep your feet on the boards!
so if anyone is thinking, they are sick and tired of their feet only fitting on half of your floor board, this seems to be the FIX!
