Here's my setup so far: 2012 SG w/ 4" Rineharts, V&H Power Dual headers, and Power Commander V. I'm waffling between a dyno run with a custom map or the Power Commander Autotune. Is there anyone out there that has the same or similar setup with the Autotune? I've run this same setup with the dyno/custom map on my past two Street Glides, so I know what to expect from that camp. Thanks for the input!
Did you buy any of your Stage 1 gear from Fuel Moto? If so, just call them for a map for your setup. It will be very close, and although I ran the PCV with Auto-Tune for two years and liked it very much, most riders don't really need it if they have a good PCV map to begin with. The beauty of AT is that you can change your configuration and it will apply fuel trims to adjust accordingly. Thus, if you plan on doing cams or other mods later on, just buy the AT now and be done with it.
Here are two threads I started quite a while ago about the PCV-AT, if anyone is interested:
Thread 1 (Note that three years ago the AT used two modules, but now there is only one.)
