Revolution Performance EMS
Old Nov 23, 2012 | 04:48 PM
  #51
bigbluff's Avatar
bigbluff
Default 2012-13?
It's been a long time since anyone has posted anything on the Revolution Performance Precision EMS. Just curious about a couple of things...
Now that it has been out for a couple or three years, what is the verdict? Those of you who are using it, how do you feel about it? Did it perform as promised? Are you still using it?
I've noticed that there does not appear to be a RevPerf EMS offering for the 2012-2013 Harleys. Has research and development stopped on this product? If so, how long will those that have already been sold continue to be supported by Revolution Performance?
Old Nov 23, 2012 | 10:09 PM
  #52
cruzmisl's Avatar
cruzmisl
Apparently they gave up on the project for 12-13's. Which is sad because mine worked like a champ. If you want one for those years you need to get an 11 ECM
Old Nov 24, 2012 | 03:28 AM
  #53
mike5511's Avatar
mike5511
Originally Posted by richie
Have one on my 07 Fatboy, previously had a PC V , way too much stuff under the seat with the PCV and every modification I made or would make required a map or a dyno, huh. Bike runs smoother now, has plenty of power, and I can do 20% displacement upgrades without needing to do anything , what is not to like . Oh I can;t tweek 1 or 2 HP at 250 bucks a pop and have maps to look at following dyno tunes to make things "better" when it is already better for me. Quite happy with miine so far , been about a yr now , no issues.
Rev Perf customer service was great, answered all my questons,2 day turnaround, it all worked for me .
Good luck to you , I believe you will be happy with your decision .
I'm another satisfied customer as well! Went to it when I did the changes below. Had true duals, SE AC, and SEPST with dyno tune prior to going to the RevPerf.
Old Nov 24, 2012 | 04:16 AM
  #54
marvincbr's Avatar
marvincbr
Originally Posted by mjb765
I wasn't concerned with transport charges or even if Rev Perf wnated to charge the next owner for programming of their ECM, but I did ask them the specific question about selling the O2 sensor module used and was told that I couldn't since it married itself to my VIN.
Is this correct? I was planning on selling the EMS I had on my 07 since it will not work on my 2012. If true, I guess I'm going to be SOL....
Old Nov 24, 2012 | 07:59 AM
  #55
Lowcountry Joe's Avatar
Lowcountry Joe
Default Revolution Performance Engine Mgmt System
Mine still works as good as the first day I installed it. This is my third HD, the first with a PCII and the second with a SERT. The RP EMS is light years better in so many ways based on my experiences with the other two "tuners".
I will admit that if you are the kind of guy that likes to mess with tuning your bike instead of riding it, the EMS is not for you.
Some guys say that their "tuners" don't recommend it. Well, if you think about that a minute, of course they don't. The dyno guy is in direct competition with the RP EMS or any other system utilizing wide-band O2 sensors and engine load as opposed to the tuner's alpha N throttle position approach. They dyno guy is not needed with the modern systems regardless of what you read here on this forum. (I am sure the dyno guys will reference this comment in order to support their investments in dyno tuning). Seriously, I am not hitting on dyno tuners, just saying that with the appropriate system, there is no need for their services.
As for post 2010 ECMs, it's my understanding that RP has not yet cracked into the 2011 and later Delphi ECM. They must do this to unlock the power of the stock ECM and modify the parameters needed for the system to work properly. Apparently HD has designed 2011 and later Delphi ECMs with some kind of wall that has so far prevented access.
The only solution (at least what Rev Per told me when I inquired) for those with a 2011 or later bike is to purchase a 2010 ECM, then you are good to go with the RP EMS system. That adds to the expense of an already expensive system, so it will no doubt turn some guys off. But if you factor in the the cost of competing dyno-needy tuners, cost of multiple dyno runs, frustration when it doesn't work, cost of more dyno runs, etc., then the EMS starts looking better and better.
For those of you new to tuning, or for those of you that would like to hear about the system from the horses mouth, check out this video to get a much better understanding of the system, why it was designed they way it was, how it utilizes the power of the stock ECM coupled with Bosch wide band 18mm O2 sensors, and maybe gain a deeper appreciation for the r&d behind this product. I have no relation to the company, just bought and installed their product on my 2010 Ultra and I could not be happier with the results:
http://www.youtube.com/watch?feature...&v=qGSlCC5oHuY
Old Nov 24, 2012 | 03:33 PM
  #56
marvincbr's Avatar
marvincbr
The gentleman that I spoke to at Revolution Performance said the same thing when I inquired about a system for my 12 RGC, purchase a 2010 ECM ($200) from them and I could continue to use the EMS I already own. I do not know if the '10 ECM would simply plug into my '12 though... If the EMS is indeed married to the VIN on my 07, I don't see how that would work..
Old Nov 24, 2012 | 03:42 PM
  #57
HDV-GLIDE's Avatar
HDV-GLIDE
My bike runs well with the EMS, only issue I see are my plug are running black like the fuel mixture is too rich. That's both plugs. No fuel smell or smoke out the pipes and my MPG is around 42 +/-, so I guess I can't complain too much.
Old Nov 24, 2012 | 03:55 PM
  #58
Puttnutt24's Avatar
Puttnutt24
I've been running the EMS system in my '07 RK for a couple years now. Three sets of cams, a couple exhaust systems and a big bore kit later and this bike has never missed a beat. And no, it has never been sniffed by a dyno yet. No complaints here...
Bburns08
Exhaust System Topics
May 1, 2016 07:24 PM
TCR5.9
24
Jun 22, 2011 09:58 PM
CoastlineAmps
Jun 14, 2011 03:10 PM
ColoSpgsMark
Nov 22, 2009 06:58 PM
Geezer Glide Bob
Feb 13, 2007 10:08 AM
