Trying to tighten up the sound/bass
Old Feb 9, 2012 | 11:50 AM
bald1der's Avatar
bald1der
Default Trying to tighten up the sound/bass
Now before yoiu audiophiles start beating me up, yes I know the sound won't be perfect, I'm just trying to tighten it up a little. For those of you who have tried the J&M Fairing/Speaker Acoustic Pad Kit, did it work for you? How noticable of a difference did it make? Thanks....
https://www.denniskirk.com/jandm-cor...prd/408574.sku
Old Feb 9, 2012 | 11:59 AM
mkguitar's Avatar
mkguitar
something on the backside of the speakers will help dampen some of the hard midrange frequencies.
the kit looks pricey- how about some foam and contact cement.
Mike
Old Feb 9, 2012 | 12:55 PM
shore's Avatar
shore
You're never going to get "bass" out of the options we all go to for the front fairing. Biggest best 6.5's with an amp will still not deliver. They might "hit" better and be louder but that "bass" we are all after doesn't exist from the fairing.
Old Feb 9, 2012 | 06:33 PM
bald1der's Avatar
bald1der
I understand I won't get as much "BASS" out of a fairing. As I said I was wondering if the kit would tighten up what bass I do have.
Old Feb 9, 2012 | 06:54 PM
sortasuave's Avatar
sortasuave
There's really nothing you can do about this.
The problem has to do with the fact that your moving in an open air environment at 65+ MPH. Once you do that, all chances for ANY form of bass go right out the window.
Old Feb 9, 2012 | 08:58 PM
JohnScrip's Avatar
JohnScrip
I have the J&M 7.25's and it's no secret that I'm pretty happy with them.
THAT SAID -- I'm an audio engineer by trade and I'm well aware of the fact that acoustic foam is pretty worthless. Including the foam that comes with the J&M's. That stuff is probably effective at 4kHz and up -- Not 400Hz and down.
In the fairing, the best you can hope for is to tackle some of the resonance of the cavity. I ended up using a sheet of Ballistic -- http://www.ballistic-online.com -- you can get it at most car stereo shops. Added enough mass to the fairing to attenuate the boxy resonance pretty well. It certainly won't "increase" the low end (which really doesn't even develop until you're a few feet behind the bike), but it stops you from hearing the fairing resonating to the music. Installs in no time, trims with scissors.
Lemme see if I have a photo...
Attached Thumbnails Trying to tighten up the sound/bass-ballistic_in_fairing.jpg
Old Feb 9, 2012 | 09:28 PM
bellgnte's Avatar
bellgnte
Midrange and highs are a directed sound. Easy to get even on a lawnmower (jk). You can forget about bass. Nothing for the sound to bounce off of. That is why a truck stereo can sound so darn good. The other posters are right. Don't spend your dollars trying to get bass. Headphones will give you that sound your looking for...lol
Old Feb 9, 2012 | 09:50 PM
fabrik8r's Avatar
fabrik8r
I used a high density foam kitchen mat, and it made a pretty noticeable difference. I don't know baby **** from apple butter when it comes to sound engineering, but there was a sound guy that said the foam I used was very well suited. https://www.hdforums.com/forum/touri...r-fairing.html If nothing else its a good excuse to hang out in the garage and drink beer
Old Feb 10, 2012 | 05:06 PM
PowerSmoke's Avatar
PowerSmoke
Originally Posted by JohnScrip
I
I did exactly the same thing John did, using Dynamat I bought from Bestbuy. Mine ended up looking almost exactly the same as his.
It does make a little difference in the thin bass response, but dont expect to suddenly rattle windows with it.
Your absolute best bang is going to be adding larger speakers, at least 6.5's.
Regardless, as mentioned above, any bass is totally gone above about 25-30 mph anyway.
Old Feb 10, 2012 | 07:05 PM
Harleypingman's Avatar
Harleypingman
I used Dynaxorb squares made by Dynamat and noticed a fuller sound; noticeable, but not a "WOW" improvement.
It significantly reduced the vibration in the outer fairing.
Carl
