My recent solution to the tricky problem of Ignition switch removal/install. Mr. Stealer would like you to step up and buy their specially designed, trick "Ignition Alignment Tool", however, I'm just too dang cheap.
Wonder if it's marketable?
Yea not really sure what is in there but there are several weighed or what ever you want to call the inside and a pain in the a.... But if ya just keep messing with it will finally hit the right spot and every thing will line up and be done , I just used a screw driver
