Tail light wiring
Old Feb 17, 2012 | 12:40 AM
minesweeper's Avatar
minesweeper
Default Tail light wiring
Broskys, I am installing two 12 inch each LED light strips to aid the rear light on my RK Custom. Does any one know the color of lead wire and the color for the tail light at the quick connect under the seat? I need to add more light to my rear than just the tail light alone.
Old Feb 17, 2012 | 01:07 AM
mkguitar's Avatar
mkguitar
on recent models:
black ground
blue run
red brake
older models
green run
red brake
mike
Old Feb 17, 2012 | 07:54 AM
katobird's Avatar
katobird
Not sure if your Rk has it..
I used the wires for my tourpak lights.
Bought the little pigtail and installed 2 12" strips witha 1/2" X 1/2" angle and mounted it under the tourpak..
worked out really well
Just comes on with brake lights
you need a photo let me know I'll take one
Old Feb 17, 2012 | 05:23 PM
minesweeper
Originally Posted by mkguitar
on recent models:
black ground
blue run
red brake
older models
green run
red brake
mike
Thank Mike, will give it a whril.
Old Feb 17, 2012 | 05:32 PM
minesweeper
KATOBIRD, I am sure I have a plug&play connector, but would have to track it down. I'd like to see that pic, I'll post mine once i get it hooked up. thnx.
Old Feb 18, 2012 | 12:22 PM
katobird's Avatar
katobird
Hope this helps.
You can only see it from behind and bending down.
It sits about 3" from read of tourpak, As you can see from the Signature piture also
Attached Thumbnails Tail light wiring-led-2-.jpg   Tail light wiring-led2edit.jpg
wc00000001
May 27, 2018 09:54 AM
hhkiwi
Apr 15, 2015 03:41 PM
Pt0872
Mar 27, 2013 01:55 PM
emperor wurm
Apr 24, 2012 11:40 AM
GREENOHAWK69
EVO
Mar 8, 2011 10:57 AM
