SE Pro Tuner question
Old Feb 17, 2012 | 09:57 PM
aviscomi's Avatar
aviscomi
Nevermind, I found it. Thanks!
Old Feb 18, 2012 | 01:34 AM
1Canuck's Avatar
1Canuck
Originally Posted by aviscomi
How do I select Advanced Tuning?
do you see the CD with screw driver icon along the top? then the 4 arrow icon.
Old Feb 18, 2012 | 06:54 AM
aviscomi's Avatar
aviscomi
Yes...I actually getting ready to load the modified map into the VCI now.
Old Feb 18, 2012 | 07:43 AM
aviscomi's Avatar
aviscomi
Does the black button on the VCI start & stop (pause) the recording?
Old Feb 18, 2012 | 08:34 AM
aviscomi's Avatar
aviscomi
I got the new map uploaded to the ECM, seems to ride better. I am getting throttle hesitation and a little back-fire @ 3,200ish RPM in 4th gear. Any thoughts?
Old Feb 18, 2012 | 11:26 AM
2009blackpearle's Avatar
2009blackpearle
Default are u runnnig in closed loop or open
if its in closed loop dont matter what u do to the map it will always keep afr at 14.6
if i recall the other day i looked up 120 maps for another post think there is about 5 maps for 120 did u update your ve tables after the runs-- the smartune should have done this when u generated a new map. the other maps will have different timing most likely , iwent through about 5 maps on mine until igot the slug out. I also did about 5 test runs to make a new map.
here is a bunch of post from other se tuner stuff maybe there will be stuff in here to help
https://www.hdforums.com/forum/touri...mart-tune.html
Pizzahog
Jul 30, 2015 10:56 AM
aviscomi
May 19, 2012 09:39 AM
scarygt
15
Jan 10, 2012 12:37 PM
wolffman13
21
Aug 18, 2011 09:44 PM
pargenz
Jul 24, 2011 03:53 PM
