Hogtunes/flash
Old Feb 15, 2012 | 06:36 PM
vailtl's Avatar
vailtl
Default Hogtunes/flash
Hi all,
Just installed the 5X7 hogtunes in The front fairing of my 07 roadglide
And I also put The HT rear speaker pods on. I took The bike in and got the radio flashed for the fader. The fader will not fade out the rears. I tried switching the HT amp from 2ch to 4ch still nothing any ideas. I followed the directions to the T..
This is The new 160 watt amp it has a switch for 2&4ch.
I would sure like to be able to turn down the rears for when the wife is rideing.
Thanks.
Old Feb 15, 2012 | 06:47 PM
mikebaby's Avatar
mikebaby
Does the fader work if the amp is disconnected? The first thing I would do is verify the flash works without the amp.
mikebaby
Old Feb 15, 2012 | 07:49 PM
piesik650's Avatar
piesik650
first thing for me is how do you have your amp hooked from the stereo? just the 4 wires from the front two speakers? or did you tie into it somehow to factory back speakers?
Old Feb 15, 2012 | 08:39 PM
Harleypingman's Avatar
Harleypingman
Don't know how the inputs on your amp are wired. For the fader to work, you need to have front and rear outputs from the HK head unit to the amp's inputs.
Carl
Old Feb 15, 2012 | 08:53 PM
piesik650's Avatar
piesik650
Carl
Yeah that's what I ment to say.
Old Feb 15, 2012 | 09:27 PM
Wally's Avatar
Wally
call Pez at Hogtunes.
Old Feb 16, 2012 | 09:29 AM
vailtl's Avatar
vailtl
I realize now that the fader will not work in my application.
I am just running my system off the front part of the HK radio.
Thanks you guys were all right.
Sorry.
Old Feb 16, 2012 | 10:32 AM
Harleypingman
It's pretty easy to access the rear speaker pin-outs of the HK radio, and connect them to your amp. It may be that PEZ has a plug and play harness for this application, or you can make your own as explained in this thread:
https://www.hdforums.com/forum/touri...head-unit.html
Carl
Old Feb 18, 2012 | 12:16 PM
vailtl's Avatar
vailtl
Default Thanks
Carl
Thanks for the info I will give that a try.
Delzore
Audio Systems
May 21, 2019 09:29 PM
RWood
Audio Systems
11
May 23, 2016 01:51 PM
todderickson
Audio Systems
11
Aug 29, 2013 06:36 PM
Hogpro
Audio Systems
Aug 15, 2013 07:36 PM
dynacop25
Audio Systems
May 13, 2013 02:19 PM
