Crossover Gasket
Old Feb 20, 2012 | 12:22 PM
TedMan's Avatar
TedMan
Default Crossover Gasket
Have read a lot of threads on this and didn't see what I was looking for. I'm going to replace my crossover gasket, as the one in there is kind of beat up, and this is the third time on and off for the exhaust. Anyway, as far as removing the old one, are there any tips or shortcuts, beside just picking it out of there with a small screwdriver? Thanks ahead of time with any advice.
TedMan
Old Feb 20, 2012 | 12:34 PM
Scuba10jdl's Avatar
Scuba10jdl
I use a pick to pull them out, and then grab with a needlenose plier to pull them the rest of the way out. Sometimes they can be a little stubborn.
The new one might be a little hard to compress in the pipes at first, too. Just give it a good push (pushing the pipes together at the crossover) and it will smoosh in there. You'll know when it is crushed and in place.
Old Feb 20, 2012 | 12:35 PM
'05Train's Avatar
'05Train
They're a bastard to put back in. Try freezing the thing overnight.
Old Feb 20, 2012 | 05:25 PM
Lowcountry Joe's Avatar
Lowcountry Joe
This gasket does not "crush" into place. To properly install a new gasket, you will have to expand the mouth of the crossover pipe to the proper diameter necessary to easily slide the gasket in. Do it any other way and you will screw it up and have to buy another gasket. Been there, done that.
Old Feb 21, 2012 | 10:23 AM
TedMan's Avatar
TedMan
Thanks all. I have a pipe expander which I will use. Just didn't know if there was a secret to getting the old one out.
TedMan
Inop
EVO
26
May 29, 2025 08:36 AM
TedMan
Feb 21, 2012 06:37 PM
klf33
Aug 8, 2011 11:52 AM
OneBlackFly
Dec 22, 2007 08:55 AM
Kyddworks
Exhaust System Topics
Sep 22, 2007 09:48 AM
