Ultra Classic electrical problem.
Old Feb 21, 2012 | 11:52 AM
spamby's Avatar
spamby
Stage IV
Default Ultra Classic electrical problem.
Hello, I haven't been on here in awhile.
Here's some background on my problem.
I have a battery tender on my battery all this winter. I was going to ride in a funeral and went and warmed my bike up. Was going to take it for a shake down ride before the funeral acouple of days later. Well I warm it up and notice a loose panel, and to make it easier to tighten down(it was on the top of the fuel tank) I removed the seat and then replaced it. I had no power, so I removed the seat and started looking at wires and my battery post. The battery tender pig tail that I had installed on the battery sparked at the negitive post. So I removed the pig tail and reconnected the battery. So I take it for a ride and now my gauge on the dash for the voltage was fine but half way around the ride(less than 30 miles) the guage started going down and I lost my radio display and when I made it home it would not restart. Fast forward today. I charge the battery up and get it started. Same thing gauge goes down. I check the fuses and they seem fine. Looking at the wires and don't see anything that jumps out at me. I guess my question is should I keep looking at the wires or is it the alternator? And if its the alternator how much do they usually run.
Sorry for the long story.
Thanks for any help.
Old Feb 21, 2012 | 12:05 PM
mkguitar's Avatar
mkguitar
could be alternator ( expensive for labor)
regulator
or a burned cable
best to have it go to an experienced tech unless you have a basic knowledge of auto-electrics
the service manual outlines the simple diagnostic checks with a voltmeter.
there is also a tutorial on the electrical tech forum, you could read it over
mike
Old Feb 21, 2012 | 12:18 PM
Nute's Avatar
Nute
Battery appears to be taking charge from tender so I would suggest the battery is good. Bike seems to be running off battery. You could have a bad voltage regulator, bad altenator, or just a bad connection to the bike. Look in your maintenance manual it will tell you where to put the test leads on your reg. and alt. If they check out good then you will have to find the bad connection. It could be just a bad ground.
I forgot to mention, you should first check to see if you are thowing any codes. If you are it will point you the right direction to start trouble shooting.
Old Feb 21, 2012 | 12:46 PM
spamby's Avatar
spamby
Stage IV
Thanks for all the input. I will start troubleshooting and post up what I find.
Thanks again.
Old Feb 21, 2012 | 01:38 PM
Ribitt's Avatar
Ribitt
Cool
the altenator would be stator and it sounds to me your battery just wont hold a charge.
Old Feb 21, 2012 | 04:58 PM
journeyman's Avatar
journeyman
Most likely you missed a connector when you removed the pig tail from the battery, there are several, one of which goes to the regulator (the one that charges the battery), check it and be sure they are all connected.
If they are all connected, I would check the battery first, then the regulator.
Let us know what you find.
Old Feb 22, 2012 | 06:37 PM
Nute's Avatar
Nute
If the battery takes a charge from the tender and doesn't discharge right away when a load is put on it the battery is good. From what you are saying it sounds like the system isn't charging. To confirm battery is good take it to an automotive centre and have them check it out. It could be as simple as loose connection or a bad ground.
Another quick check is to take the inspection cover off the primary. If it stinks like (you know what) your stator is toast and will need to be replaced.
Old Feb 22, 2012 | 08:30 PM
Lowcountry Joe's Avatar
Lowcountry Joe
Since your radio and associated electronics were working OK initially, then they start flaking on you the longer you ride, it's your stator. Since the battery charges and the bike starts and runs fine off of a charged battery, then is dead when you limp home, it's your stator. It's toast brother.
Heres a link to a video that will give you an ideal of where the stator/rotor (combined they make up the "alternator" for your bike) are located:
http://www.youtube.com/watch?v=4F_p3rsqjSA
Stinking primary fluid is a positive indicator of a bad stator.
My brother has his stator replaced at a harley shop for $200 total. Me, I would do the work myself, but that's just me.
Old Feb 22, 2012 | 08:36 PM
ultra_classic's Avatar
ultra_classic
well i suspect you left a wire off or our alternator isn't charging, if you charge the battery and it starts ok, then check the battery volts with a volt meter, with battery charged it should be around 12.5v and running and the Alternator working properly, it should be 13.5-14.5v. good luck
Old Feb 23, 2012 | 01:49 PM
spamby's Avatar
spamby
Stage IV
Thanks guys, I've been busy but I will check and see if its the stator. Will post what I find.
thanks
again
HDJIM1158
Aug 16, 2014 01:37 AM
MattFXDB
Apr 11, 2012 09:27 PM
slipvayne9278
Jul 22, 2011 12:39 PM
mudsweatNgears
Aug 8, 2010 05:09 PM
DiegoKing
May 9, 2009 09:41 PM
