Do You Hit Your Rev Limiter?
Old Feb 25, 2012 | 08:06 AM
  #31
oasis03's Avatar
oasis03
Mine hit me back.
Old Feb 25, 2012 | 08:07 AM
  #32
hd_rolling's Avatar
hd_rolling
Hell yah I hit the limiter, but I'm still under 40 yrs old. You need to ask this in the sporty/softail/dyna sections, I'll bet that most of the younger guys do. Did it on my last bike and every so often on this one, a little more now that I have the new cams. I don't think I have seen a newer harley with a blown engine from over revving, not saying its good for the engine but your bikes not going to explode the first time its going to hit it either, why would they raise it from 5400 to 6200 if the engines couldn't handle it?
Old Feb 25, 2012 | 08:09 AM
  #33
pt4u2nv's Avatar
pt4u2nv
Originally Posted by shortride
i don't think the rpm's on my '09 ultra classic have ever been over 3k.
what !!!!!!!
Old Feb 25, 2012 | 08:12 AM
  #34
smitty901's Avatar
smitty901
Limiter is set low so hitting hurts nothing.
how ever you should be shifting before you get there.
Old Feb 25, 2012 | 08:13 AM
  #35
turn8a's Avatar
turn8a
I thought it was a rev limiter and not an age limiter . lol
Old Feb 25, 2012 | 08:25 AM
  #36
run1fsr's Avatar
run1fsr
Thumbs up
Originally Posted by fabrik8r
The OEM rev limiter is set at about 5400, gurantee that considers a wide margin of operational safety, since you can raise it to 6200 without any problems via PC or HD download. While the power does start to drop off in the high RPMS, the bike doesn't stop pulling the moment the TQ curve breaks over the apex, the machine is already in motion so it doesn't require as much power to continue accelerating. They are designed to do at least what the rev limiter allows, hence the rev limiter. If they were only good to 3500 RPMs, thats where the rev limiter would be set. That shifting at peak TQ technique is a much more abrupt power transition between gears, power drops back further in the curve in the next higher gear than it does shifting after the curve starts to dip, which puts you at a stonger point in the curve in the next higher gear. Theres also nothing wrong with riding easy, but my bike, I pay the bills, I do the wrenchin, I ride it the way I want. You can make up all the excuses in the world to ride it like a moped if you want to but there is really no need to look for reasons why somebody else is wrong for the way they ride. It ain't like I'm riding your bike hard.
Well written. I suspect that you are a person I would enjoy riding with
Old Feb 25, 2012 | 08:34 AM
  #37
Teardrop's Avatar
Teardrop
Originally Posted by Stiggy
I have 103,000 miles on my bike.
I have never hit the rev limiter.
I believe there is a connection.
I agree with this statement and hope to have 103k on my bike some day.
Old Feb 25, 2012 | 08:40 AM
  #38
checkers's Avatar
checkers
No, does not sound odd to me, sounds like he must be a mature rider. I never "hit" my rev limiter. This was one of the best questions I have ever read on this forum. I have put many days of thought into this, Dude.
Old Feb 25, 2012 | 09:00 AM
  #39
ramair1's Avatar
ramair1
If drag racing you generally want to shift to maxmize power. The common misconception is that you should shift at or right after the torque peak.
If interested, here a couple web sites that discuss this is more detail. Draw your own conclusions.
Motorcycle perspective:
http://motorcycleinfo.calsci.com/Horsepower.html
Automobile:
http://www.allpar.com/eek/hp-vs-torque.html
http://www.vettenet.org/torquehp.html
Finally here is a graph for a stock 96" showing speed versus torque in each gear. When you shift you will loose rpm based on the gear ratios.
You would want to shift where the lines cross between gears for this set up:
Old Feb 25, 2012 | 09:05 AM
  #40
da2ofusgb's Avatar
da2ofusgb
I have hit the rev limiter a few times and no damage done, when in the heat of the moment things happen and if ya bring it up to quick oh well, just enjoy the ride.....
By the way I,m 58 and still ride it like I stole it!!!!
