Looking for advise/experience
Old Feb 25, 2012 | 01:45 PM
mkguitar's Avatar
mkguitar
I had a gorilla on my evo EG, it was great.
cheap, 1 wire hook up- worked just fine.
shock/tilt sensor, electrical sensor, special chirp on disarm IF the alarm had been activated while I was parked
I had mine mounted in front of the lic plate ( under the tour pak)- well concealed, and the siren was able to project
I also have the xena- the alarm often goes off when I am removing it with the key, so I put my hand over it !
but at least I don't try to ride off with the disc lock in place.
both of these are good inexpensive solutions
mike
Old Feb 25, 2012 | 01:49 PM
jjnoble's Avatar
jjnoble
Originally Posted by shortride
Here is an inexpensive alternative siren from Radio Shack you can install yourself.
Originally Posted by potter
Ok I have got a quick question about the siren intall. I have a 08 EG Std. It has the "alarm when you turn the switch off the lights flash. And it wont restart unless you have the key FOB.
Can a siren be added simply has described in other threads. I think it was wireing into a exsisting plug? And how does the siren churp or what ever when the lights flash?
THANKS in advance
Yes, that is the question shortride was answering. Click on the link he gave, there are instructions and pictures.
Old Feb 25, 2012 | 01:58 PM
motorcyclelockman's Avatar
motorcyclelockman
I wired 2 sirens into my bike. You talk about screaming. If you can't ignore it. IT IS LOUD!
Old Feb 25, 2012 | 04:48 PM
potter's Avatar
potter
What is the point to removing the main fuse. Other than having the alarm go off while working on the bike. And If you have your key FOB with you, shouldnt be a problem.
Toypuller
Oct 9, 2017 09:54 AM
AlCherry
Apr 19, 2015 07:26 AM
mduncan62
Audio Systems
13
May 25, 2013 12:55 PM
Mikechk
Oct 30, 2012 02:08 PM
D6CS
May 25, 2008 03:12 PM
