noise coming from rocker boxes???
Old Mar 2, 2012 | 12:52 PM
polish hammer's Avatar
polish hammer
haha its not my twinkie although i love all harley motors
pan and shovel n evos r my engine of choice
with a twinky last
Old May 12, 2012 | 06:01 PM
uncle bucket's Avatar
uncle bucket
BUMP time
I am chasing a similar noise & have been awaiting others outcome with similar problems.
Mine started in stock form, 09 Ultra whilst traveling a 4500mile trip.Knocking started lightly & has progressed to a solid hollow sounding metal rap.
Changed cams, lifters, pushrods etc on return....no difference.
Had a few so called experts listen & test ride with nothing positive to come out of it, in regards to identifying the damn noise.
Primary has been apart & just now checking rockers etc......found nothing at all other than a crook tensioner, but put in new gear drives now.
New 551G S&S cams are the greatest single upgrade done yet, but the knocking noise is just getting louder
Any thoughts welcome, before the frustration kills me
Old May 12, 2012 | 07:54 PM
freak65753's Avatar
freak65753
Stage I
I have this same issue with a 2011 SG 103, it started right after the 10000 mile service, no mods, Harley is clueless
Old May 8, 2013 | 08:47 PM
edfromptowne's Avatar
edfromptowne
Default rear rockerbox noise
i have 2007 softail std , with a stethoscope you hear the rattle as it decelerates from blipping the throttle. my pushrod will manually spin when at rest but you can feel a tight spot
im thinking the rocker bushings/bearings. with 43,000 miles im dissapointed at the weak engineering that has these twin cams faultering, cam chain tensioners,etc,
yeah,i feel like a shovelhead right now
Old Nov 2, 2015 | 08:37 PM
Ricksr's Avatar
Ricksr
Stage II
Rockout rocker shaft inserts is the fix for that noise. I had to do it to my '02 Ultra Classic. Amazon is the only place I could find the inserts. 15 bucks and I'm running quiet now. Hope this helps.
Old Nov 2, 2015 | 09:08 PM
jaxdwg's Avatar
jaxdwg
Originally Posted by polish hammer
2007 electraglide twin cam
developed a rapping noise in front rocker box when i go above 2000 rpms sounds like something rattling in there anyone else get this? gonna take it apart soon looks like i gotta pull tank to do this?
I went through this. I changed lifters, and replaced pushrods with adjustables, then pulled and installed new rocker arm shafts, then finally figured out it was piston slap. It started about 70k but I didn't figure It out until 96, at which time I did the whole top end with the 95" kit, heads, cams, bla bla. The skirts of those piston were screwed, and I got the rattle at about that 2k up you speak of. How many miles on yours?
Old Nov 3, 2015 | 06:05 AM
GTK's Avatar
GTK
Come on guys,I'm sure the op got the problem solved over 3 1/2 years ago.
vittt000
EVO
Aug 12, 2012 02:21 PM
Milan
Exhaust System Topics
Jul 15, 2009 07:10 PM
popstheoldman
Ironhead
Sep 5, 2008 11:30 AM
Chuck1
Jul 1, 2007 11:07 AM
webscrounger
Jun 8, 2007 05:41 PM
