Tourpak
Old Mar 3, 2012 | 11:35 AM
skratch's Avatar
skratch
Originally Posted by 6speed51
So, I got a new Tourpak from Harley,what do you plug all the holes with as I am not applying a backrest.There's six small holes and one big hole.A trip to the hardware store is in my future.
Originally Posted by shortride
use the hole plugs for 4 of them. the other 2 go through the tether strap mount plate and you'll want to put some small bolts through them to keep the plate from popping off and your tourpack lid flopping all the way over and breaking at the hinge mounts.
springer 03's Avatar
springer 03
Doh!!
Old Mar 3, 2012 | 11:56 AM
funnythebunny's Avatar
funnythebunny
Why spend all that $ on a tour pack that will never be used as intended? You would have been better off with a detachable tour-pack rack and the bungee touring luggage onto it (like T-Bags or similar). You would have more room at the end.
I'm just sayin'...
Old Mar 3, 2012 | 12:06 PM
EricD10563's Avatar
EricD10563
Seems to me the Tour-Pac was intended to pack things and the byproduct is that you can lean against it not the other way around. It's called a tour-pac not a backrest-pac. The ability to lock it up, be out of sight, grab the bag inside and not undue everything is worth the expense if you do a lot of traveling which I do.
Old Mar 3, 2012 | 12:53 PM
DeneFXDWG's Avatar
DeneFXDWG
I'm thinking of a chopped pak from HD also. Just wondering if you could tell me what yours came with? I know I'd need a backrest of some sort but what about the hinges, latches, lock and tether cord? Did the hardware come installed ready to use? Thanks for any info.
Old Mar 3, 2012 | 01:11 PM
skratch's Avatar
skratch
comes with hinges and latches. you'll have to buy the locking mech separately. slide your black plastic cover off your key and order by that code. then you'll only need the one key to open your saddlebags, tourpack, steering lock, etc. the lock is cheap, around $20. it comes all put together, just install on your rack and go.
now you can buy the upgraded hinges, latches, and retractable tether. but you don't have to.
Old Mar 3, 2012 | 02:38 PM
brandss's Avatar
brandss
Holy Crap. 6Speed, bet you never planned on getting so much crap for asking a question. Use the tour pak any darn way you want. People, lighten up
Old Mar 3, 2012 | 03:51 PM
springer 03
Just pull a trailer and be done with it! DOH!
Old Mar 3, 2012 | 04:05 PM
DeneFXDWG's Avatar
DeneFXDWG
Default Thanks skratch!
All I need to know.
Old Mar 3, 2012 | 05:32 PM
6speed51's Avatar
6speed51
I'm used to taking and giving crap,this thread has given me some good information.I see that a few riders see my point of view.If you camp while on the road you will appreciate all the room you can muster.
xprmntl1
2014-2024 Touring Models
Dec 16, 2014 11:20 AM
Ben E
Oct 25, 2011 02:48 PM
RG32
Touring Parts
Aug 6, 2010 07:38 AM
62trvler
Mar 10, 2008 04:39 PM
Cohiba_Joe
Mar 21, 2006 04:27 PM
