Just got done installing dresser duals rinehart slip ons pcv and se heavy breather,just took it for a short run and she backfired when i shifted,its about 35 degrees out but i wouldnt think that should matter.I got my pcv from fuel moto mapped with my set up so i doubt that is an issue.Could it be an exhaust leak and if so how can i tell?
It may be an exhaust leak. Here is a way to find it:
Get a 2-3 ft piece of plastic hose (water hose or smaller diameter clear hose from home depot). Put one end by your ear. Move the other end all around the exhaust joints/connections while the engine is running. You will hear the difference where there is a leak.
It is my experience that if you follow the manual instructions on how to install the exhaust, you have a pretty good chance of not having an exhaust leak. I just installed my exhaust after the 255 cam upgrade and it is leak-free.
Some other items... Do not re-use exhaust gaskets or clamps (they tend to become oval if over tightened). Use a bead of high temp RTV Silicon on the inside of the mufflers before installing them on the headers (to seal better, this is from the Rinehart manual). Use a tube spreader (cheap from Harbor Freight, medium size) to expand header/muffler end points that have the cuts.
