PCIII or SERT?
Old Dec 21, 2006 | 10:32 PM
Custom07RKC's Avatar
Custom07RKC
Default PCIII or SERT?
Would like some advice. I'm installing a SE A/C and some true duals, V&H Big Shots i believe. I was wondering which ECM tuner i should go with. I do not plan on doing other performance tuning to the bike besides the pipes and intake. It is on an 07 RK Classic. Also,t he Big Shots have the O2 ports, should i leave the sensors in or eliminate them?
Old Dec 21, 2006 | 10:37 PM
JeffSG's Avatar
JeffSG
Default RE: PCIII or SERT?
There are lots of threads out there on this subject. Here is a good one...https://www.hdforums.com/m_988844/tm.htm .
Based on all I have read here, you should go with a PCIII and a dyno tune by an experienced tuner.
Ride safe,
Old Dec 21, 2006 | 10:46 PM
maineultraclassic's Avatar
maineultraclassic
ORIGINAL: Custom07RKC
If I was you, I would go with the PCIIIusb. It will come with the o2 sensor eliminators, so you can install a map and get rid of the lean, overheating stock condition.
Check out www.fuelmotousa.com or www.easternperformance.com for the PCIIIusb.
Steve
Old Dec 21, 2006 | 11:59 PM
Indianspringsaz's Avatar
Indianspringsaz
Both are good, I would try the search tab. About 50% will tell you to go with the PC3, the other half will tell you to go with the SERT. I went with the SERT based on my own research, advise from friends and tuners. I dont think you will disappointed in either one.
[sm=popcorn.gif]
Old Dec 22, 2006 | 12:21 AM
ndotken's Avatar
ndotken
PCIII. User programmable and portable.
Old Dec 22, 2006 | 12:46 AM
Retired_Ted's Avatar
Retired_Ted
The SERT takes someone who really knows his business to tune it - The PC III is much friendlier to tune. Either will do the job - find out what your mechanic prefers.
Old Dec 22, 2006 | 01:17 AM
geargrinder's Avatar
geargrinder
ORIGINAL: Retired_Ted
The best mechanics are lousy computer tuners, the best computer tuners are lousy mechanics, what a delema....
Old Dec 22, 2006 | 01:47 AM
turbo54's Avatar
turbo54
I have been seeing around N M the tuners have learned how much better the sert is to tune , There are so many more variables with the sert.If your bike requires the fine tuning like my RG .Nothing worse then rideing and having the PC crash and pulling over to disarm it.
Old Dec 22, 2006 | 10:15 AM
GreighWolf's Avatar
GreighWolf
There are several threads on this topic. To me it boils down to two questions... 1) who is doing the tune??? 2) which device dothey perfer to use???
https://www.hdforums.com/m_1066308/tm.htm
I have the seRT. with my laptop, I can do anything to my bike that can be done w/ PCIII and then some
and the seRT doesn't have to stay piggybacked on my ECM.
Old Dec 22, 2006 | 10:42 AM
sparky_mo's Avatar
sparky_mo
ORIGINAL: turbo54
Is the PC crashing something that happens a lot? I was wondering how many, with the PCIII, this has happened to?
