Rear Shock Install Help
Old Mar 8, 2012 | 05:15 PM
Hobbymike's Avatar
Hobbymike
Default Rear Shock Install Help
I just pick up a set of Premium Ride Shocks. My question is can you install them without a jack by replacing one at a time? Or do you need to jack bike up to do it?
Old Mar 8, 2012 | 05:38 PM
mkguitar's Avatar
mkguitar
take the bike up a few inches on a jack
I use a wedge shaped block of wood under the tire to move the axle up/down to match where the lower shock mounts hang...
careful not to unbalance the bike.
1st time you do it it'll take 20 minutes.
use the same air lines, make sure ALL the air is out before popping the line
mike
Old Mar 8, 2012 | 06:08 PM
Spur56's Avatar
Spur56
You need a jack. No air lines on premium shocks
Old Mar 8, 2012 | 06:29 PM
qtrracer's Avatar
qtrracer
If they are the same length as the ones you are replacing you may get by without a jack. I did mine without a jack and the new shocks were 1.25" longer than stock. You just gotta get creative.
zeke7142003
Apr 19, 2018 08:42 AM
Twinrider
Jan 27, 2017 08:30 AM
smoen81
Oct 22, 2011 11:41 PM
JustDave71
Jun 26, 2010 09:57 PM
shekmark
Mar 16, 2009 08:13 PM
