NEED HELP! Speakers are hissing
Old Mar 11, 2012 | 05:45 PM
JoeTag's Avatar
JoeTag
Default NEED HELP! Speakers are hissing
I installed an ARC amp with the Titan-Hertz speakers. The sound is so much better but now I have a hissing sound coming off the speakers that you hear at very low volume or even if the radio is off. I wired You can only hear with the engine off. Has anyone experienced this? Is it normal? Thanks..
Old Mar 12, 2012 | 08:24 AM
JoeTag's Avatar
JoeTag
No one has experienced this or has a solution?
Old Mar 12, 2012 | 08:28 AM
Tripp_HPjunkie's Avatar
Tripp_HPjunkie
I had that problem when listening to pandora threw my phone but never with a cd or usb drive or radio......does it do it now matter whats playing?
Old Mar 12, 2012 | 08:33 AM
IBHarley's Avatar
IBHarley
make sure you have a good ground on the amp seem to remember hiss from when I used to put car stereos in
Old Mar 12, 2012 | 08:40 AM
Northbound Southerner's Avatar
Does this amp have a gain control? I so, back off of it until the hiss goes away and see how you like the sound level there.
Old Mar 12, 2012 | 09:02 AM
JoeTag's Avatar
JoeTag
It could be the ground. I grounded to the exiting ground on the tree but I did not use any wire brush. It may be is not getting a good ground. It is a b@tch to reach that area.
Old Mar 12, 2012 | 09:04 AM
JoeTag's Avatar
JoeTag
Yes, even when it is off.
Old Mar 12, 2012 | 09:14 AM
Akitakoi's Avatar
Akitakoi
Try turning the gain down and your receiver volume up.
Old Mar 12, 2012 | 09:28 AM
VTL nut's Avatar
VTL nut
You are getting noise.....
Put a choke on the power line to the amp.
An inductor in series, and a cap to ground.
Go to radio shack and ask for a line filter, they will be able to set you up...
Old Mar 12, 2012 | 10:05 AM
piesik650's Avatar
piesik650
Ground would be my first choice, does it change when you turn on a blinker or hazards? you could have voltage or interferance causeing it. and I always try to keep my ground wire less then 18" long. are you runing a factory deck? or do you have RCA imputs into the amp?
Another thing its always a good idea to use dialectric grease in all your conectors.
