Strange occurrence
Old Mar 12, 2012 | 12:24 PM
slhanks4's Avatar
slhanks4
Default Strange occurrence
Yesterday I rode my Limited to my son's house and parked in the driveway. Driveway is fairly steep, so when I went to leave, I had the ignition on, but I just pulled in the clutch and slowly backed down to the street. I had only moved a foot or two, and I heard what I thought was a pop, then a sizzle and saw smoke. It came from behind the air cleaner assembly.
Once I got down on level ground, I started the bike, checked all the gauges, lights, etc. Everything worked fine, and I rode it 25 miles to home with no problems.
I didn't have time to remove the air cleaner and look around to see if there was obvious damage. Anybody have any idea what might have happened?
Old Mar 12, 2012 | 12:27 PM
Sgt_Torque's Avatar
Sgt_Torque
Sounds like you "bumped" your engine over one rev and the residual gas ignited.
Old Mar 12, 2012 | 12:28 PM
sgdiesel's Avatar
sgdiesel
Drop of oil fell on to hot engine?
Old Mar 12, 2012 | 12:30 PM
ElectraGlideSteve's Avatar
ElectraGlideSteve
My guess is you just ignited some unburned fuel, kinda like a backfire, and hiccupped or popped back through the A/C.
Old Mar 12, 2012 | 12:45 PM
Ganooch's Avatar
Ganooch
I second. Sounds like an A/C burp. Carbed bikes do that a lot, though it is admittedly rare for an EFI bike.
Old Mar 12, 2012 | 02:10 PM
slhanks4's Avatar
slhanks4
The engine was cold, it had been sitting in my son's driveway for 4 hours or so and it was only 75° out at the time.
I was thinking since the ignition and fuel pump were on, I rolled back a little bit, released the clutch lever in 1st gear causing the engine to turn over a little and must have ignited some unburned fuel. That was my initial thought, although I didn't know if it was possible with a FI bike. The smoke I saw was coming from within the air cleaner, which had the appearance of coming from behind the air cleaner assembly.
Old Mar 12, 2012 | 03:30 PM
HTNHARD's Avatar
HTNHARD
I don't think its recommended to pop the clutch a little while backing up. Didn't even know it could be done, unless I'm out in left field here.
Old Mar 12, 2012 | 03:38 PM
Captain Itch's Avatar
Captain Itch
Sponsor
If you get time look behind the Backing Plate at the plugs and wires that go to the throttle body.Make sure the plug is tight..
__________________
www.Captain-Itch.com
Old Mar 12, 2012 | 03:43 PM
Geoff's Avatar
Geoff
I agree.
Goretto
General Topics/Tech Tips
Jan 14, 2019 08:51 AM
Babyboy
Engine Mechanical Topics
Aug 20, 2015 04:42 AM
toyman57
2014-2024 Touring Models
May 11, 2015 10:46 PM
AAAC
EVO
16
Apr 9, 2014 10:37 AM
Bsod
May 12, 2012 01:55 PM
