Checking/cleaning air cleaner and found this
Old Aug 19, 2015 | 08:44 PM
Babyboy's Avatar
Babyboy
Default Checking/cleaning air cleaner and found this
My by monthly checks
Pulled air cleaner cover off today and got a suprize!! Then checked oil level and coolant level.This is what I foundđŸ˜* oil level down almost 1qt, coolant low and milk in the breathe head bolt on front cylinder. On my '14 Limited
Attached Thumbnails Checking/cleaning air cleaner and found this-20150819_180337-1.jpg   Checking/cleaning air cleaner and found this-20150819_180500.jpg   Checking/cleaning air cleaner and found this-20150819_180900.jpg
Old Aug 19, 2015 | 08:53 PM
soft 02's Avatar
soft 02
Water is normal. The engine just hasn't got hot enough to burn it off.
Old Aug 19, 2015 | 08:57 PM
Babyboy's Avatar
Babyboy
The scoot is 13 months old and has almost 16,000 miles on it.I ride every day and this was after a 40 mile ride home at 70 mph and 85 degrees.
Old Aug 19, 2015 | 09:02 PM
soft 02's Avatar
soft 02
Still normal. What is your relative humidity? I drain about 1/4 cup of water out of my breather catch can every 200 miles.
Old Aug 19, 2015 | 09:11 PM
Babyboy's Avatar
Babyboy
Humidity would not have a factor after the engine temp is at a constent for the length of time it takes me to get home.
Look close at the breather bolt there is antifreeze on it
Old Aug 19, 2015 | 09:24 PM
soft 02's Avatar
soft 02
I was under the impression that the coolant passege was no wear neer the breather passege. Besides that once the coolant pressurised it would flood the intake via the breather passege. Best of luck.
Old Aug 19, 2015 | 09:27 PM
Jackie Paper's Avatar
Jackie Paper
Combustion process produces a lot of moisture and once engine is hot, usually goes out exhaust as steam and you never see it. However, it could get caught in plumbing of vent. Looks a little like rusty water but if you say antifreeze, guess it's that. If so, also should be on dip stick. However, one case of here where Harley is now saying it will leak into engine from the pipe fitting cast into the head. There is a bunch of PDFs on water system repair problems. One is a dye test.
Old Aug 19, 2015 | 09:33 PM
soft 02's Avatar
soft 02
Still won't get into the pcv hose. Wrong side of the head. A crack at the exhaust seat and it could get into the combustion chamber. Still think it's nothing though but I've been wrong once or twice.
Old Aug 19, 2015 | 09:40 PM
Babyboy's Avatar
Babyboy
I understand the combustion process and creating condensation and heat getting rid of the condensation.But the loss of almost a quart of oil in 1000 miles is a little much.
I am just looking for any info or possible on going problems that others have had with the 103 wet heads
Old Aug 20, 2015 | 04:42 AM
Jackie Paper
I would have thought same thing. However, Harley must have found it since it's in the manual. If it gets into cylinder in excess, it's going to drive past rings.
See post 5 and 43 here.
https://www.hdforums.com/forum/new-r...015-ultra.html
djKail
May 8, 2016 05:23 PM
monarchy
Aug 13, 2015 07:43 AM
R3d_Rid3r
Aug 13, 2012 04:56 AM
Bsod
May 12, 2012 01:55 PM
xcbiker
Jul 12, 2007 11:12 PM
