MPG Help
Old Mar 14, 2012 | 12:22 PM
sargek's Avatar
sargek
'07 Ultra, stage one: PC-III with custom 'advanced' map, K&N AC, Jackpot dyno-tuned slips and I get about 35-36. I ride in the 2600-3200 range and normally shift close to 3k. Never use 6th because I am never in a situation where I can ride that fast so not sure what the mileage would be. Bone-stock the bike got about 42 but the heat and detonation was unacceptable. Bike runs awesome now so afraid to mess with the map too much - dyno tune might help but I can't afford one right now. Can't get real gas here, only 10% ethanol crap.
Old Mar 14, 2012 | 12:45 PM
mkguitar's Avatar
mkguitar
From what I see, power commander= poor MPG. ( I ride behind guys with PC and I can smell the unburned fuel)
many PC set ups don't use the o2 sensors, so the ECM doesn't know IF the motor is running rich- or lean.
The cell values may not be accurately metering fuel optimally. ( the ECM is operating blindfolded)
the acknowledged throttle problem, higher speeds ( wind resistance*) have alot to do with this. As may the regional fuel blends. MPG is reduced by about the same percentage as the ethanol added to fuel, as ethanol provides fewer BTU's-and is displacing 10% ( +/-) gasoline
OP, try this.
Remove the power commander, install nightrider.com XIEDS ( about $115) and see what happens.
If you have no improvement, you can sell the Xieds on the classifieds and get some of your cash back.
I have an 09 FLHTC and avg 43 MPG at 70 MPH, loaded down, measured over thousands of miles. I have the stock no cat headers, supertrapps tuned slip ons, and a ness big sucker, along with the xieds.
( before the Xieds I got 44 mpg)
Mike
*MPG on my last FLHTC , evo 80" was measured under many conditions for 15 years, this gives an idea of what wind speed does
65 MPH = 45 MPG
70 MPH = 42 MPG
75 MPH = 36 MPG
85 MPH = 32MPG ( or worse)
Old Mar 14, 2012 | 12:51 PM
HD Jim's Avatar
HD Jim
Would there be any advantage to adding octane booster to gas with 10% ethanol or any ethanol for that matter?
Old Mar 14, 2012 | 01:05 PM
mkguitar's Avatar
mkguitar
No octane rating represents the ability of the fuel to resist ignition.
( a low octane fuel can "self ignite" under compression like a diesel, we want the fuel to resist compression ignition, and burn when the sparkplug fires)
Mike
Old Mar 14, 2012 | 01:25 PM
Dew Me's Avatar
Dew Me
Have the same bike: Same year, PC-V, Bub 7's, stock headers, and SE Intake. I'm also in the DC metro (MD side) so I know all about 95. I haven't been happy with my mileage either. Been a while since I checked it but think I'm getting about the same as you. Ripping through the gears isn't doing you any favors but I think a big problem is that these things aren't even the slightest bit areodynamic. I find myself clipping along at 80 quite often and have no doubt there is a severe mileage drop between 65 and 85.
I did remove the baffles and installed BCT's but that shouldn't matter.
Funny what Mike said about smelling unburned fuel b/c I swear I do when I let off on the throttle to often.
Jaime offered to change my map once. Said it would likely run too hot if he did and it already seems to run hot so I don't want to run any hotter.
I think you (and I) should be getting better mileage. Wish I knew what the problem is. IF there is a problem. Only thing I can think of to try is a new tuner but I don't have the cabbage for that kind of experiment.
Old Mar 14, 2012 | 01:31 PM
HD Jim's Avatar
HD Jim
Mike
Mike... thanks for your answer. Wasn't sure if adding a Octane booster would help or hinder my MPG. I ride in areas that sometimes 93 octane isn't available.. would adding a octane booster to a lower grade fuel be a plus or negative ?
Thanks
Jim
Old Mar 14, 2012 | 01:37 PM
mkguitar's Avatar
mkguitar
Thanks
Jim
I carry octane boost when touring, bad or mis-rated gas will cause the bike to ping, resulting in poor operation
( motor damage is unlikely as the ECM will usually sense and retard timing enough--- which reduces power greatly)
Worst fuel I ever got was at a Chevron in Blythe, CA headed West.
What pissed me off is that I was facing 110 miles ( to the next services) with a 4000' elevation change and had to baby the bike. That's when i started carrying the booster.
and then there are the crooks:
http://fuelfix.com/blog/2011/08/18/t...ting-gasoline/
mike
Old Mar 14, 2012 | 01:46 PM
Tailgunner1's Avatar
Tailgunner1
Ethanol actually raises octane. Octane has nothing to do with MPG, it has to do with detonation.
Old Mar 14, 2012 | 01:48 PM
HD Jim's Avatar
HD Jim
mike
The worst gas I ever got was in a town called Thorndale,Tx... don't know if it was just a one time thing there but I will not by gas from that particular convenience store (go figure) Was riding to a place called Apache Pass.... fund raiser for the local VFD. I do carry a octane booster but leery of adding anything to my fuel but I know at times..it is needed.
Thanks again!
Jim
Old Mar 14, 2012 | 01:52 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
My 05 RG had a 95 inch build, PC, SE active performance exhaust, SE 1 air cleaner, SE valves, and rockers, Woods555 cams.
If I ran on cruise control at 55 mph, I would get about 38 to 44 mpg. If I bent my wrist the mpg dropped to 26............
but I would grin EVERY SINGLE TIME.
My 2011 has a stock 96..... and I mean STOCK...... I get 50 mpg most of the time. My wallet grins ALL THE TIME.
I kinda like having a happy wallet.
Last edited by shooter5074; Mar 14, 2012 at 01:57 PM. Reason: My Mom can beat up your Mom.
