2-1-2 into 2-1 after de-cat
Old Mar 19, 2012 | 07:24 AM
glide2005's Avatar
glide2005
Originally Posted by fabrik8r
Didn't you say you got them for free to play with, just do it and find out. Use a temporary cap like a freeze plug or a silicone cap you can clamp on, if you don't like it, no problem, just uncap it.
Thats what I was thinking.
Old Mar 19, 2012 | 07:42 AM
fabrik8r's Avatar
fabrik8r
I'm bettin' it works, maybe not the best performer, but it will probably work, however the one muffler from a dual system may be a little anemic, you may need to add a high flow muffler. I'll be watchin to see what you come up with, cool project.
Old Mar 28, 2012 | 05:02 AM
glide2005's Avatar
glide2005
Well the Sampson didn't work. Sounded like a 4 cylinder honda running on 2 and no power. Put the stock muffler on and runs better, but still sounds stock. Going to take the freeze plug out and put the Sampsons back on this weekend.
Old Apr 1, 2012 | 06:41 PM
glide2005's Avatar
glide2005
Took the freeze plug out this morning and put both sides on. Put a big sucker stage 1 A/C on yesterday and the bike runs and sounds great, with a hole lot less heat. I never did get good fuel milage. Alway got between 35 and 38 mpg. Now with the Xied, big sucker, no cats, and Sampsons, getting 43 mpg on the first tank. I'm a happy camper.
Old Apr 1, 2012 | 07:13 PM
TUCCI's Avatar
TUCCI
Originally Posted by Jinks
When you opened the collector to remove the cat was the rear header extended further into the collector than the front header? The 2010 2 into 1 pipes are built that way to attain the equalization that Mike refers to. If yours is built that way it should work fine. I have a 2010 pipe on my '07. That was what I found when I removed the cat, & it works just fine.
I did the same thing with my 2011 headpipe and it works just fine also....Since you've got a set of pipes to experiment with, go ahead and play with different designs and report to the forum with your findings.....thats how new inventions are made.
Mchad
Exhaust System Topics
Oct 31, 2016 05:12 PM
stratplexi
Feb 16, 2013 05:58 AM
Stretchman
Aug 19, 2012 10:24 PM
TexFF
Jul 19, 2012 03:44 PM
Rebel78
Oct 13, 2011 10:02 AM
