2 into one nightstick - 2012 flhr - possible?
Old Aug 15, 2012 | 11:04 PM
Stretchman's Avatar
Stretchman
Default 2 into one nightstick - 2012 flhr - possible?
is it possible to mount a 2 into one nightstick to the stock header of the 2012 flhr? Is there a major performance increase, and do they do a reflash and air cleaner with it?
Old Aug 15, 2012 | 11:36 PM
JCleary's Avatar
JCleary
The exhaust will actually be more restrictive than stock. The Nightstick has one 1-3/4" inlet, versus two 1-3/4" on your stock mufflers.
If it was a normal 2-1 with a large collector and, say, a 2.5" or 3" inlet on the muffler (like a Thunderheader, Bosszilla, Dragos or Pro-Pipe then you'd have a performance increase with the other mods.
You may gain a little torque but lose up top due to more backpressure. I've got a complete '10 FLHX exhaust if you want to try it. Just pay shipping...
Old Aug 16, 2012 | 06:41 AM
Stretchman's Avatar
Stretchman
The 2 into 1 is 1.75?
80881-10 is the part number I am talking about.
I have kitty in the pipes.
Going to leave it there. The talk on those pipes is with a good stage one reture, that they work pretty well. Face it, if I can't get a Harley to run ok with a 103 and a 6 speed, EPA, or not, then I might as well go back to an 80 inch Evo, which moved the weight pretty well.
Now that that's covered, I have no idea why people relate sound to HP/TQ. What I want is performance. What I want is legal performance. Not really difficult, if you know what you're doing. I'd recam before I'd rip the cat, only because I kind of think that it's a good idea, as bad as it sucks. Stock this tank has grunt that I never knew existed. I'd simply like to smooth it out at the bottom end. I want more torque, and I want it instant on, but also, good on the highway to about 85. That's where I ride my Harley. Pretty sure it can easily be done.
Back to the original question. Can a 2 into 1 pipe be mounted on the stock header? Does the crossover come off and leave a 2 into 1 header, or does the header need to be swapped too? How much weight, and what are the heat issues with the nightstick 2 into 1? More or less? Tunable disks sound ok, and I could stay 2 into 1 into 2 if it was cheaper than a header swap. Just no need right now. Since the cat is better hot ( the way it works ) I might wrap it to keep radiated heat down as well. With the velocity increase at the tips, the hotter inside the pipe the better.
Old Aug 16, 2012 | 08:09 AM
Roadie 49's Avatar
Roadie 49
Friend has a stock FLHX,96", with factory 2 into one exhaust.
Dealer installed a nightstick muffler and after a couple hundred miles
the muffler is yellowing.
Dealer said reflash wasn't needed,but I'd say it's running to hot or the muffler is crap quality.
Old Aug 16, 2012 | 08:41 AM
Ronp42's Avatar
Ronp42
Account Retired
The header has to come off because your stock header is longer than a 2into1 header. I ended up going with a 2into1 header off a 2010 Street Glide and bought a 2into1 Powertube muffler from Jamie. If you go that route you will need a set of 2into1 chrome header shields too. I didn't like the setup and went back to my stock header. I still have it boxed and it's in great condition if you want it.
Old Aug 16, 2012 | 09:17 AM
12XU's Avatar
12XU
I have an '11 FLHRC. You could take the left side exhaust off and cap the outlet from the cat/collector portion. I don't think that would gain you anything except the look you want. The big question comes down to the inlet diameter of the new muffler matching to the outlet of the collector. The catalog doesn't say what that is... I run Jackpot pro touring mufflers with their asymmetrical baffles. The left has a restrictor ring in it. It essentially acts almost like a 2 into 1. I run this with the stock headpipe minus cat, with great results.
Old Aug 16, 2012 | 09:22 AM
Matt990724's Avatar
Matt990724
+1 Ronp is right
The 2:1 Mufflers are designed to work with the stock 2010 SG headers. They are 4" shorter behind the collector, so the 2:1 Mufflers are 4" longer.
I just did this swap into the 2010 2:1 Header on my 2012 RGC. And just as Ronp said, you will at least need the 2010 heatshield for the collector, as it is 4" shorter also. (the rest of the heatshields are interchangeable from what I could tell)
Old Aug 16, 2012 | 09:24 AM
Ronp42's Avatar
Ronp42
Account Retired
You can't do that unless you are leaving the stock right side muffler or going with a 2into2 right side muffler. The 2into1 muffler's are longer. I would talk to a tuner before plugging the crossover pipe. From what Jamie from FuelMoto told me, It will cause an imbalance and excess heat for rear cylinder.
Matt990724's Avatar
Matt990724
The diameter of both headers is the same.
When I swapped headers, I didn't have the new muffler yet, so I ran to the local muffler shop and had them make me a 4" extension and slapped on the stock exhaust on for a couple days waiting on FedEx. The only difference is the length.
Off the top of my head; Thunderheader, Rush, V&H, and BUB make 2:1 mufflers for the 2010 setup. I am sure there are others, but those the ones I am sure of.
Old Aug 16, 2012 | 09:32 AM
0ldhippie's Avatar
0ldhippie
It has been done before using a freeze pug. Pretty easy. Can't imagine there is any performance gain going to less flow than stock?
