Replaced clutch spring, issues! help
Old Mar 18, 2012 | 01:32 PM
JRBass's Avatar
JRBass
Not sure how the ***** and ramp would be affected since they are held in place with a large snap ring to prevent them from coming apart and you haven't been in that side of the tranny obviously the way you are talking about not wanting to remove the exhaust and all.
Old Mar 18, 2012 | 02:03 PM
BIGVTWIN's Avatar
BIGVTWIN
Did you torque in the sequence from the manual.
Old Mar 19, 2012 | 11:07 AM
mainshaft's Avatar
mainshaft
I did the same this years ago, and the clutch acted the same way. The sping was the wrong one. Good luck.
Old Mar 19, 2012 | 12:06 PM
Leftcoaster's Avatar
Leftcoaster
Not loosening the cable and not re-adjusting the clutch pack will cause the very thing you describe.
Try adjusting the spring pack with the cable full lose. Then adjust the cable and you should be back in business.
jeffbetrollin
Dec 8, 2015 02:15 PM
corys87l
Feb 11, 2013 03:27 PM
outlawrider
Aug 15, 2010 09:55 PM
Raventhik
May 31, 2010 03:29 PM
mkmclm
Mar 7, 2010 07:14 PM
