Replaced clutch spring, issues! help
Old Mar 18, 2012 | 09:03 AM
pittz5's Avatar
pittz5
Default Replaced clutch spring, issues! help
So I replace the stock spring with the Barnett HD spring. Pretty straight forward and easy. got everything back togeather and now the clutch isnt working. Pull lever and put bike in gear and it wants to take off without letting clutch out?? I have tried to adjust everything about 10 times now with same results? Anyone have any ideas of what I could of done wrong?
Old Mar 18, 2012 | 09:17 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Just curious... why were you compelled to change out the spring? Clutch slipping?
Old Mar 18, 2012 | 09:23 AM
pittz5's Avatar
pittz5
I bulit motor with s&s106 and was getting some slipping so I wanted to try spring first. Going to pull everything apart again today and see if I missed something? 2 hr job has turned into whole weekend job and its still not rideable. sucks! ;-(
Old Mar 18, 2012 | 09:27 AM
Lowcountry Joe
Might be worth a call to Barnett to get their take on the issue. I bet they have coached folks through this before. Sorry about all the trouble. But you will get it whipped, no doubt.
Old Mar 18, 2012 | 09:42 AM
pittz5's Avatar
pittz5
for those who have replace their stock spring for the SE version, have any of you had issues like this? I am baffled here. Thinking about putting stock spring back in just to see if it works. PITA!
Old Mar 18, 2012 | 10:59 AM
boom23's Avatar
boom23
I've replaced the stock spring with a little heavier one, without re-adjusting anything, and the clutch behaved the same...
You might want to re-check the install and adjust as per manual.
Old Mar 18, 2012 | 11:09 AM
1flhtk4me's Avatar
1flhtk4me
May have to check the ***** and ramp on the other end.
Old Mar 18, 2012 | 11:27 AM
aviscomi's Avatar
aviscomi
+1 after ensuring that the *****/ramp are oaky,you should have "slacked" the clutch cable on the way prior to the install, then tightened it enough to allow 1/4 inch paly in the lever...I think.
Old Mar 18, 2012 | 12:00 PM
speakerfritz's Avatar
speakerfritz
check with the OEM.....some of these kits specifically recommend tranny fluid instead of gear/motor oil.....your plates might just be sucked together from using the wrong fluid.
Old Mar 18, 2012 | 12:12 PM
pittz5's Avatar
pittz5
always only used Harley Primary fluid. How do I ensure ball and ramp are ok? I dont want to pull exhaust and all that crap. Heading out to garage now to pull everything back apart. Fun Fun! Does it matter if the cable is slacked before or after spring install?? The manual doesnt specify how to change just the spring, probably cuz its should be super easy!
