How do you adjust primary?
Old Mar 21, 2012 | 04:06 PM
2106HD's Avatar
2106HD
Question How do you adjust primary?
OK, So I drained the fluid and see that my chain is a little loose. I loosened the bolt and the adjusting shoe fell all the way down. How do you move it up and keep pressure against it while you tighten the bolt. It keeps wanting to fall back down and I can't get enough fingers in there to pull it up. Whats the trick??????
Old Mar 21, 2012 | 04:31 PM
Lucky1958's Avatar
Lucky1958
compress it and tie it with a zip tye. Then adjust up tighten then remove zip tie. wala
Old Mar 21, 2012 | 05:17 PM
2106HD's Avatar
2106HD
Thanks, that was the charm.
Old Mar 21, 2012 | 06:33 PM
Roadking Cal's Avatar
Roadking Cal
Get yourself a H-D factory maintenance manual. The part telling you about adjusting the chain tensioner says to loosen the nut only one full turn. that keeps the whole thing from doing to you what it did to you.
The manual should be the first and most valuable thing in your tool kit.
Glad you got it fixed!
Old Mar 21, 2012 | 08:19 PM
Punjabi Rider's Avatar
Punjabi Rider
Make sure to check for pressure point by turning it you don't want it too tight at any location.
anubisss
Oct 1, 2008 07:52 PM
OkieOutlaw
Jul 1, 2007 02:40 PM
WdGldDave
Aug 4, 2006 12:13 AM
yota
Jul 3, 2006 07:33 AM
gtrman
May 25, 2006 06:27 PM
