Quick Question Oil Drain Plug...
Old Mar 23, 2012 | 06:29 AM
  #41
mrfikser's Avatar
mrfikser
Originally Posted by iwillfixthem4u
I do not use anything on threads but noticed that Harley does use it at the factory. The shop manuel does not call for anytng but an O ring.
my 08 streetbob (96 motor) came with pipe dope on the plug from the factory....as did my 11 flhrc...I wonder who knows better the folks here or the guys who built the bike/motor....
Old Mar 23, 2012 | 07:31 AM
  #42
fabrik8r's Avatar
fabrik8r
A manufacturer would never use a shortcut trick on the assembly line to get a unit to pass QC inspection. Its not a matter of who knows better, yes they come from the factory with pipe dope on the threads of an O ring plug, but that doesn't make it right, and its funny the service manual says nothing in writing about using a secondary sealant, only to inspect the O ring and replace as necesssary. You could smear pipe dope on your oil filter sealing surface and that would still work too, but you would never do that because it adequately seals on the O ring and an additional sealant is not necessary.
Old Mar 23, 2012 | 09:44 AM
  #43
journeyman's Avatar
journeyman
If I had to guess why the factory puts something on the threads of the o-ring plug, I would say it’s likely for lubricating and protecting the threads.
When two different metals are put together they could form a corrosion battery and could bond together.
Anti-seize, a little oil, or some grease would do here, so why not? There must be a reason why anti-seize is not used. Maybe due to the solid lubricating particles in anti-seize, and risk of getting some of it in the oil. Oil or grease, I would guess somewhere a plug has loosened up and fell out – new motor warranty risk.
Then there is Teflon paste – dummy proof, it lubricates and protects the threads, it helps hold like Loctite, and a little in the oil probably won’t hurt either. Teflon paste is also used for sealing taper threads, so false assumptions are made and a dealer service monkey will glob it on and ignore the critical o-ring seal.
Most of us are quite satisfied with a little oil on the o-ring and threads when properly tightened.
Old Mar 23, 2012 | 10:02 AM
  #44
Leftcoaster's Avatar
Leftcoaster
This comes up constantly - just saw the same topic only last week.
The factory AND the dealers both use pipe dope/teflon tape. They are MORONS (and so is anyone else that does this).
If you have any HD dealer service your bike absolutely insist that there be no pipe dope (or tape) used on your drain plug.
If you find pipe dope on your plug clean it off with diesel fuel - it works the fastest. Get a new, properly sized o-ring that fits in the groove snugly. Lube it with some motor oil and tighten it up no more than 'snug'. No torque wrench necessary.
Pipe dope will push the o-ring out of it's groove and cause it to tear resulting in a leak. It also can and will lead to galling of those fine threads in your spendy aluminum cases.
Old Mar 23, 2012 | 10:03 AM
  #45
Leftcoaster
Sorry, double post due to super slow submit reaction.
Old Mar 24, 2012 | 10:48 AM
  #46
redlohsom's Avatar
redlohsom
Update:
Exhaust mount bolts to Tranny where tight. there was a little excess oil in A/C so drained and refilled with only 3qts. wire's at front of crank case are sealed with hightemp silicone. Oil filter checked. No oil cooler on this bike...and it still leaks..So my only guess would be once again the inner primary seal I'll let it go for the summer and keep an eye on the fluid level. its not low, neither was tranny. Next winter I'll plan a bigger project and do it then. Can't see spending $80. in parts and a whole day just for a small leak.
Old Mar 24, 2012 | 11:17 AM
  #47
leon anthony's Avatar
leon anthony
you do not need no stinkin tape
Old Mar 24, 2012 | 11:21 AM
  #48
NDBadlands4-2's Avatar
NDBadlands4-2
The O ring will cost less than a dollar, and 3 quarts of oil are not that much either. Just change the oil and fix the plug.
Old Mar 24, 2012 | 03:10 PM
  #49
speakerfritz's Avatar
speakerfritz
pump the oil out thru the filler. replace the oil ring, teflon, or what ever you think will work, refill the oil . Pep boys sells a basketball size pump that I use to pump out oil of bikes and cars I don't want to screw around with drain plugs on.
PhatBoyHigh
Nov 25, 2015 11:11 AM
aces&8s
EVO
11
Sep 8, 2013 09:43 AM
Tonefiend
Oil Archive (no new posts)
Sep 26, 2010 09:04 AM
mikes4692003
Engine Mechanical Topics
Aug 11, 2009 02:53 PM
harleydom55
Aug 11, 2008 05:09 PM
