Monkey Bars - pulling wires Jeeeeeeesus!
Old Mar 26, 2012 | 03:40 PM
vzts4q's Avatar
vzts4q
Stagger the wires and use a good wire pulling Lubricant
I have been using Yellow 77® Wire Pulling Lubricant for several years and have never broken a wire when pulling.
http://www.idealindustries.com/produ.../yellow_77.jsp
Did mini apes on the wifes FXDSE2 with no problem.
Also pulled 5 strands of RG6 and a antenna rotator wire through about 15 feet of 1" PVC after the "profesional" installer pulled the RG6 in half because he wouldn't wait 30 seconds for me to get the lube.
Lube is you friend!
Old Mar 26, 2012 | 04:33 PM
Glen1978's Avatar
Glen1978
I did my softail on my own and it sucked. Swore I would never do another set. Six years later I get my FLHX and decide on 10" MBB's......here we go again. I pulled it all apart, got everything I needed and worked on it about an hour.....**** that! Called my indy up and he said bring them down. He got it done in a hour for $75 bucks.....I threw him a $100 and walked the hell out with a smile. Defeat....maybe. I dont care. Im happy, my wife still talks to me and I still have all my hair. It was a win/win for me.
Old Mar 26, 2012 | 06:12 PM
mike1158's Avatar
mike1158
Originally Posted by fish eye
Send them to me, I'll pull them through.
Did you switch over to the Screamin' Eagle TBW sensor? It eliminates the green clip, which will give you a headache.
I've pulled two sets of these (14" bars) and each time, I pull the TBW sensor through about 95%. Then, run the right side controls, and finish it off with the left side controls.
There are several threads on here about wiring these bars. A quick search may yield more tips.
If you were closer i'd DEFENATELY take you up on that... thanks man
Old Mar 26, 2012 | 08:25 PM
Nightrain04's Avatar
Nightrain04
Originally Posted by mike1158
NightTrain - did you stagger the wires so the pins weren't all together?
did you pull the throttle by wire lines together with the controll wires or did you pull them seperate?
I staggered a little bit on the right side. I did the TBW, then the control wires. I cut the factory loom and left about 5" of it by the switch housing where the control wires go into the bars. Then I wrapped the the wires with electrical tape. I used a piece of the factory loom where the wires come out my the clamp. I was able to get the left side thru with the factory loom on, just used the rope with a knot zip tied above the pins and tape over the rope wires and pins. Its more of a push then pull. You gotta have patience.
I was sent a copy of the the Yaffe instructions, seems to me they would work well on the regular apes with normal bends. The 1/8" nylon rope worked great for me.
Old Mar 26, 2012 | 09:03 PM
Gunnysgt's Avatar
Gunnysgt
I used the same type wire they use for electric fences to pull my wires thru the WO577. Strong stuff and stiff enough to push and pull. I also used a bunch of silicone spray lube. Got both sides done in about 45 minutes.
Old May 8, 2012 | 08:43 PM
Dew Me's Avatar
Dew Me
I just finished the 10"Monkey Bagger Bars. I had Yaffes instructions and read them but I really didn't refer to them once while pulling wires. I bought the SE TBW. I managed to squeeze all the wires into 1/2 shrink which may have been harder than pulling through bars. I didn't shrink it though. I did make sure there was lots of extra shrink at the end, shrunk it, flattened it, tripled it over, hole punched and used some real strong rather thin string I had sitting around. Tied a nut to then end so gravity would bring the string through. Went through pretty easy. A lot of patient push, pull, push, pull. You think you'll never finish, wonder if it is working, and BAM they are out. Did the easy ones second (left). I left them in factory shrink and they went right through. Almost forgot, I did spray some silcone in both sides.
I'd do it again, and will have to do it again. Yaffe didn't chrome under my grips and my grips are the Battistini swiss cheese grips. Pissssssed!!!
Wires took less time than I thought. Everything else took more time than I thought. I really took my time though and triple checked things. Had some cable challenges. Partially b/c they are pushed up as close as you can get the the fairing and b/c of my T-Bag bags. Wait till you see how I ran my clutch! When I'm all done and have time I post something up
Old May 12, 2012 | 11:08 AM
jamminjimmi's Avatar
jamminjimmi
2 things here….DONT pull the plugs apart! Cut them off leaving a few inches of wire on them, solder the extra length of wire on and heat shrink. After the wires are pulled through then reattach the plugs. Vaseline can be used as a lubricant to ease them around the top bend of the bar. Just my .02
Old May 12, 2012 | 05:02 PM
Dew Me's Avatar
Dew Me
Here are some pics. I'm gonna do some looking. I think I have some that show better what I did with the clutch cable.
Attached Thumbnails Monkey Bars - pulling wires   Jeeeeeeesus!-spring-12-and-pyo-053.jpg   Monkey Bars - pulling wires   Jeeeeeeesus!-spring-12-and-pyo-052.jpg   Monkey Bars - pulling wires   Jeeeeeeesus!-spring-12-and-pyo-057.jpg   Monkey Bars - pulling wires   Jeeeeeeesus!-spring-12-and-pyo-059.jpg   Monkey Bars - pulling wires   Jeeeeeeesus!-spring-12-and-pyo-058.jpg
Old May 12, 2012 | 05:32 PM
Dew Me's Avatar
Dew Me
OK, these show my re-route of clutch cable. Visor bag covers everything as you can see in pics above. After drilling I used a file and angle filed to lessen arch of cable. Bought a rubber grommet at Home Depot to finish it off. A lot like the Harley one in the lower original hole but rubber isn't as bulky looking. When I paint inner fairing I'll have that original whole covered up.
Yes, I know I wasted a bunch of money buying cromite braided cable that nobody will ever see. Oh, well, by the time I paid shipping cost savings woulda been minimal and I'd have had to wait. Happy I figured out how to hide it.
Attached Thumbnails Monkey Bars - pulling wires   Jeeeeeeesus!-spring-12-and-pyo-040.jpg   Monkey Bars - pulling wires   Jeeeeeeesus!-spring-12-and-pyo-041.jpg   Monkey Bars - pulling wires   Jeeeeeeesus!-spring-12-and-pyo-044.jpg   Monkey Bars - pulling wires   Jeeeeeeesus!-spring-12-and-pyo-047.jpg   Monkey Bars - pulling wires   Jeeeeeeesus!-spring-12-and-pyo-048.jpg
Old Apr 15, 2016 | 07:20 AM
tonymontanna1983's Avatar
tonymontanna1983
Um, OK, I'm stealing that idea, thank you very much ^^^^^^^
That really looks great, very good job!
