Update: Still hesitating engine after SERT--Help!!
Old Mar 28, 2012 | 09:48 AM
leicafish's Avatar
leicafish
Originally Posted by iclick
Baloney. As has already been said, a new bike will run smoothly right out of the box with no tuner or dyno tune and without misfiring. If it is running so lean as to make it misfire it is a warranty issue. I would call HD customer service and tell them what the dealer said and what they sold you as a fix. I would demand a refund, as they had no business selling you a bill of goods that they knew should've been handled as a warranty issue.
This is similar to the problems I was having with my '07, but in my case it was the TPS, and its your good fortune that you don't have one. There is a connector on top the induction module of some (all?) TBW bikes that can cause problems like this because of bad contacts. Also, a leak in the corrugated hose inside the tank can cause fuel-pressure problems. Other possibilities might be a defective spark plug or plug wire, but I wouldn't bet any money on either since you aren't getting any fault codes. Clogged gas cap? Maybe, and that should be easy to diagnose.
Again, I would cease talking to that dealer until you call HD CS, and tell them the entire story of how they diagnosed the problem as a $1000 fix that came out of your pocket, which ultimately didn't fix anything. They will probably have a service rep look at the bike and they will go from there. You haven't been given good service, IMO.
iClick sound info is an understatement, It is always a pleasure to read you responses.
The gas cap thing is real, I had the same issue on one if my bikes.
Take care
Old Mar 28, 2012 | 09:51 AM
iclick's Avatar
iclick
Originally Posted by Skippy97
Took it to Harley today. Warmed up the bike well on the way, and at a stop light in town, it almost died on me.
Well, at least the bike is throwing codes now. The Harley Maintenance Manager said both the front and rear cylinders are misfiring. Plus, they found a small oil cooler leak (most likely unrelated).
The codes found were:
P0134:Front Oxygen sensor inactive
P0154: Rear Oxygen sensor inactive
P0031: O2 sensor heater low/inactive
Any of these related to misfiring?
The O2-sensor codes ring a bell. Did anyone replace the exhaust system? If so, they may have swapped the O2 sensors in the pipes, and that will definitely cause problems. You can't swap the connectors, but you can put the front O2 sensor in the rear pipe and vice versa. What happens is that one O2 sensor reports a lean or rich condition and the ECM thinks it's for the other cylinder, adjusting accordingly. After a while it adjusts too much and it will misfire. If your bike has a PCV it will throw historical codes for the O2 sensors since they should be disconnected, but that's not a concern.
...while I was there talking to parts guys, the Maint. Manager quit! Walked out.
Now you've done it. You ran him off! Good. No loss to you or the dealership, IMO.
Old Mar 29, 2012 | 09:42 AM
Skippy97's Avatar
Skippy97
iClick,
I bought V&H slip-on mufflers (stock headpipes), and the Harley guys put it on for me. I had those put on in early December, and the problems started in mid-February.
Thanks for all the info...gives me lots of questions to ask if I go to the dealer and they say "couldn't find anything".
Cheers,
Skippy
Old Mar 29, 2012 | 10:35 AM
blusmbl's Avatar
blusmbl
That sounds like a wiring problem with one of the grounds going to the O2 sensors. Even if it was misfiring it wouldn't set a heater code.
Old Mar 29, 2012 | 04:00 PM
Skippy97's Avatar
Skippy97
Harley is telling me that the ECM needs replacing now.
Parts on order...right in time for the good weather.
Of course, if this is the problem, that means the tune was done on a bad ECM (the problem started before the tune). That means that they will have to do another tune with the new ECM, I'm guessing.
This just gets better and better.
Old Mar 29, 2012 | 05:13 PM
blusmbl's Avatar
blusmbl
Take it to another dealer, it sounds like they have no idea what they're doing.
Old Mar 29, 2012 | 06:57 PM
bobcat557's Avatar
bobcat557
first thing i would do is disconnect the connector to the ecm put some electrical lube in there an make sure good connection, then i would disconnect the tbw connection on bottom left side on induction module an put some electrical lube in there also. i would rule these two items out of the equation before going any further. theres been a problem with moisture an condensation on the terminals in the past, worth a shot. good luck
Old Mar 29, 2012 | 09:17 PM
V2Evo96's Avatar
V2Evo96
Originally Posted by barkingspud
If you O2's aren't working that would explain why your bike is running like crap....
Agreed if the sensors are the issue but--- sometimes a fault will throw a 'spurious' code either as a side issue of the real problem or can be unrelated to the root cause.
Old Mar 29, 2012 | 09:22 PM
V2Evo96's Avatar
V2Evo96
The dealer should be able to upload your final map from the previous tune into the new ECM no probs.
Don't let them sell you a new dyno tune when all u need is the final map installed. If they say otherwise or have 'lost' the map the dyno tune would be on them IMO as you've already paid for this once....
GA-Mtn-Rider
May 25, 2022 03:59 PM
lummy210
Mar 9, 2017 12:05 PM
jimdp
Feb 6, 2013 08:12 AM
Bobber Jay
Jan 26, 2009 04:14 PM
bamagslinger
Feb 19, 2008 07:55 AM
