100 HP Mods?
The bike is in excellent condition, about 55,000 miles, well maintained and cared for. I just had the cam chest rebuilt a little over a year ago, but all stock. That alone made quite the difference in the way it was running, but now I'm ready to spring for the good stuff. I know a lot of you guys have done this work to your bikes and I'm interested in hearing about it so I can decide the best way to go. Money is not too much of a problem, I'd just like to keep it reasonable.
It's a '99 RK Police bike, TC 88, Marelli injection (I know, but it works great.)
So fire away, and thanks!
How Fast
How Much
How Long
You pick two
So it's the balance of power/cost and reliability
You could make your bike into a money pit, cause next it's the primary drive, clutch, tranny and swingarm need upgraded.
maybe brakes too to a newer style multi piston.
suspension upgrades, wider tire, maybe a chain conversion.
* and like the rider below- the starter can't start the bike
These are many of the things which i have watched pals go through. one of my Pals dumped over 30K in "performance work" to his 2001 Road King--- which sold for under 10K when he lost his job. ( so a net loss of about $38,000 )
It was just not a friendly streetable machine anymore--- and although showed well over 100/100 at 1200' elevation, was left behind by my evo bagger in the mountains.
His carb/ignition tuning and compression/headwork was so finicky that air density conditions outside of it's "range" resulted in a poor running bike.
I've seen this over and over, buy a Harley dump money into it, loose mpg and reliability and dump it on the market.
My suggestion for guys who want to go fast is to dump that money into a lighter bike- an evo FXR is suited for high speed, they handle great and the 80" evo can reliably make 75-80 HP. My Fxrp is under 400 pounds and'll do 135 no problem, and be stable at speeds over 100 mph.
For the money you would put into your 99, you could buy an FXR or Ducati Monster or a sportbike.
my 2˘, take it for what it's worth.
Mike
If you want best bang for your buck - do not go any further and let your seat of the pants dyno decide if you're happy rather than chasing numbers. If you like your stocker now if you do the above upgrades for I'd say 2K max you'll have the biggest smile on your face you ever had and also have a good reliable easy starting bike for lots more miles.
This should put you in the mid 90's by the way - but you start chasing those last 15-20hp getting into headwork, case boring, crank, lifters, throttle body, clutch - believe me have your wallet ready!!
