Front Fork Slider...Bonehead move...help!
Old Mar 29, 2012 | 05:28 PM
Hondo65's Avatar
Hondo65
Angry Front Fork Slider...Bonehead move...help!
I bet I know the answer befor I start but... I was replacing my speedo drive gear and cable. I was tightening the slider cap nuts when...you guessed it I snapped off the bolt. I was using my torque wrench but it did not work as it should have. Worst part is I was telling my son who was helping the importance of torqueing bolts properly. last time I took off the wheel I didn't torque it I just tightened it till it "felt right"
Now my question is (and my guess is) do I have to replace the whole sleder or is there a way to remove the stud and replace it?
Thanks in advance. This realy sucks cuz money is an issue and time as I have been trying to ride to work every day that I can to save on the cost of diesel in the truck. Now I have to drive and probably wait till I can afford new slider (s) plus the time to learn to change the slider. I do have a shop manual (hence my effort to "properly" torque the nuts DOH!
GRRRRRR...
Old Mar 29, 2012 | 05:32 PM
omgtkk's Avatar
omgtkk
My guess is, if your bike is old enough to have a cable drive speedometer you will never be able to get the rest of that stud out of the fork leg. I'm sure it's well corroded in place. It's worth a try as you really have noting to loose. I would try heat and a good quality stud remover. Worst case, if you remove the lower leg you may be able to get a machine shop to get it out.
Best of luck with it.
Old Mar 29, 2012 | 05:35 PM
Hondo65's Avatar
Hondo65
'99 EGC thought that was in my sig...goofed again. looks clean enough and not corroded but...
Old Mar 29, 2012 | 05:37 PM
HDV-GLIDE's Avatar
HDV-GLIDE
GRRRRRR...
What year bike?
I have a set of take off lowers from my 09 SG that I will send you if you pay the shipping. They are in excellent condition, no marks or blemishes.
I ship FedEx Ground (to a business/cheaper) or Home Delivery. What ever the actual cost is, is what you pay.
Old Mar 29, 2012 | 05:41 PM
dawg's Avatar
dawg
You should be able to replace the stud.
Old Mar 29, 2012 | 05:56 PM
Hondo65's Avatar
Hondo65
HDV-Glide man that is a generous offer but my bike is a '99 and I am guessing they wouldn't work, I will investigate though in case they would Thanks again for the offer
Old Mar 29, 2012 | 06:03 PM
mtclassic's Avatar
mtclassic
it is an easy fix. If there is enough of the stud sticking out just heat the area up around the stud with a small torch and use a vise grips to twist it out or another tecnique is to grind a slot in it and use a screw driver. some times using a chisel to hammer it slowly out works but make sure you use heat and something like kroll or pb blaster. If it is broken flush take it to a machine shop and they will have it out in a minute.
Old Mar 29, 2012 | 08:08 PM
Hondo65's Avatar
Hondo65
Thanks MTCLASSIC, a little heat and the vise grips and walla...it is out! Now to try and find a part number for the stud, if anyone has a parts book for a '99 touring bike...the shop manual does not show the stud as a seperate part. I am gonna research before I call the dealer in the am if anyone else has this it would be appreciated...just relieved that it looks like I can fix this uh-oh with minimal fuss thanks again for the suggestions and the offers all...I love this site!
Old Mar 29, 2012 | 08:20 PM
Hondo65's Avatar
Hondo65
looks like the part number is 45840-48. I'll give it a try tomorrow...nothin is ever easy....time for a little Jack
JekyllnHyde
Jun 12, 2019 07:31 PM
justintime6423
EVO
20
Feb 10, 2018 01:04 PM
teeboz
Feb 5, 2012 08:43 PM
neurostudy
Mar 17, 2007 11:23 PM
mojo
Jun 22, 2006 05:53 PM
