Boom Speaker lids?
Old Mar 31, 2012 | 03:39 PM
PistonPuller's Avatar
PistonPuller
Default Boom Speaker lids?
I see the lids hold a 5x7 speaker. Anyone ever drop in something other than the boom speakers? I need a 4 ohm speaker. I see Focal makes a 5x7 and am wondering if it will drop right in? Or can they easily be modified to fit a 6x9?
Old Mar 31, 2012 | 04:17 PM
cycler's Avatar
cycler
I have the cycle sounds ones. But I put rockford fosgates into them. I like they way they look a lot better than the harley ones. Got mine from rockheadbikes.com for $359.00 and free delivery
Old Mar 31, 2012 | 04:50 PM
Harleypingman's Avatar
Harleypingman
A couple of observations based on my experience with the HD saddlebag speaker lids, as well as those of my good friend, TIF2 (his username here).
The HD lids use a unique hole pattern. So if you use an aftermarket speakers, you'll need to drill holes in the lid or modify the frame to install.
In my case, I used Rockford Fosgate 6x8 speakers and needed a Dremel tool to narrow the frame slightly to fit, and drill two holes in the lid to mate with the HD lids. Not a problem; but, not for those who are averse to modding anything to fit.
My friend used JL 5x7's and added some to the frame using JB Stik.
On a positive note, Hybrid Audio Technologies is making a 5x7 to "drop in" to the HD lids--I plan to buy a pair; although, I finally hooked up the RF's and they sound GREAT.
If you check the HD saddlebag speakers, the 1 ohm and 2 ohm versions both use a bridge mounted tweeter; probably to prevent water incursion if the tweeter is stalk mounted as is typical with two-way speakers. The reason I chose the RF's was that the tweeter is bridge mounted. The new HAT speakers will also have a bridge mounted tweeter.
As for installing 6x9's, hope you undertake the project.
Carl
Old Mar 31, 2012 | 05:07 PM
cycler's Avatar
cycler
Unless you went with the cycle sounds lids and their speakers which already come with an amp just power their speakers and they fit in like a glove. And i think rockhead has them also. I believe they retail for $699 and they are selling them for $629 which include lids, speakers, and amp.
http://www.rockheadbikes.com/product_p/rhb4405-0137.htm
Old Mar 31, 2012 | 09:47 PM
PistonPuller
I dont have a problem modifying, but one reason I was thinking about the HD lids was they can come color matched. I dont want to do too much handling when they are already painted. Drilling a couple holes should be that big a deal. But dremeling out for a 6x9 may be. At least trying to secure it without scratching paint.
The price for those cyclesound lids is the best I have seen yet
Old Mar 31, 2012 | 10:03 PM
Harleypingman
Suggestion: Order the HD lids color-matched then wait for the HAT "drop in" speakers--they'll be available in 2 ohm and 4 ohm versions.
If you're impatient, the RF 6x8's require very little help from the Dremel to fit nicely and sound GREAT with the RF 300x4 amp.
Carl
PS: Cosmetics are very personal, but for me, the HD lids/grilles look better than J&M's and the Cycle Sound lids.
Old Mar 31, 2012 | 10:50 PM
PistonPuller
Carl
Which RF speakers did you use?
Old Mar 31, 2012 | 11:01 PM
LADNAR's Avatar
LADNAR
I have the HD lids, and I put Polk 5X7's in them. The holes didn't line up quite exactly, but I was able to trim my speaker tabs with a pair of tin snips, and then mounted them with some 1/4" washers to snug them down.
They sound really good, and fit well.
Old Mar 31, 2012 | 11:24 PM
Harleypingman
RF T1682.
Carl
Old Mar 31, 2012 | 11:28 PM
Harleypingman
I used some speaker gasket material to assure a good seal w/ the RF T1682's.
Like I said previously, if I had it to do over again, I'd wait for the Hybrid Audio Technologies "drop in" speakers (even though the RF's sound GREAT)--whether they are labeled as 5x7 or 6x8's I don't know--but they'll be a high quality speaker with a bridge mounted tweeter.
Carl
