Strange Happening!
Old Mar 31, 2012 | 07:14 PM
Sketz's Avatar
Sketz
Exclamation Strange Happening!
Something really strange happened to my '08 RK. When I left the house to head out for a ride, the idle was kind of fast, I just assumed it to be the cold start. However, when I got to the gas station, plenty of time for it to warm up, the idle was still too fast. Next step was to apply Harleys crazy "patch" fix by turning the ignition on and off 5 times to return it to the factory idle. I couldn't remember if I had to start it on the 5th "on" or turn it back off and turn it on one more time to start. Well anyway, I did the 5 "on's" and started it on the 5th "on". Idle didn't change, so I figured it must be 5 "on's" then start on the 6th. That's when the Gremlin took hold! It started, had a little choke on startup, however, the engine light was on and I did not have any throttle control at all. I then turned the ignition off again, waited a few seconds, turned on the ignition and nothing - the start button was totally dead, only light on was the security key light. Then I though maybe my FOB battery was dead, however the security lights were not flashing. I then turned the ignition off again, waited a minute or so, tried it again and it started and ran fine the rest of the day, even after several more starts throughout the day.
I check the diag codes when I got home and there were two (not sure if they were old or new):
The codes appeared under the "P" heading and they were:
P 1511 - EFI Power Management Mode
P 2101 - EFI Motor circuit Range Performance (Actuation Error)
By turning the ignition switch on 6 times, did I enter some Diag mode to cause this - any suggestions or comments?
Thanks, Sketz
Old Apr 1, 2012 | 08:12 AM
Sketz's Avatar
Sketz
I'm assuming since I didn't get any replies or suggestions on this problem that's it's just a fluke or glitch in the electronic control board, most likely caused by my " fat fingering" when fooling with the ignition switch. Hopefully it's not the start of a problem that'll leave me stranded somewhere!
Old Apr 1, 2012 | 08:16 AM
ynots's Avatar
ynots
Bump for you
Old Apr 1, 2012 | 08:42 AM
jeffreydsilver's Avatar
jeffreydsilver
Originally Posted by ynots
Bump for you
bump again
Old Apr 1, 2012 | 08:49 AM
Keithhu's Avatar
Keithhu
Look at this thread, then post #6, and post# 22: http://www.hdtalking.com/touring_mod...ra_issues.html
anything2wheels
Carburetor Related
18
Dec 6, 2024 12:44 PM
Big Dave
EVO
11
Aug 17, 2015 02:28 PM
SecondChance!!
Mar 17, 2012 08:26 PM
aries4155
Aug 19, 2009 07:14 PM
SLP24
Jul 26, 2009 11:59 AM
